Your basket is empty
Promethean ACTIVhub for Learning Response System
Quicklinx: 725DWS00 Mfr#: AH201
ActivHub is a specially designed USB device that enables wireless connectivity for the ActivBoard range through Promethean's ActivAir RF technology. Like Bluetooth, ActivAir "channel hops" to avoid interference, and operates in the same highly regulated and globally approved 2.4Ghz frequency (with a range of 100 meters in free space). Because ActivAir is Promethean's own technology, risk of interference from other devices is significantly less than with Bluetooth or other similar devices. ActivAir also enables simultaneous use of multiple Learner Response devices and handheld telepointing peripherals such as ActivSlates through a single computer connection.
Promethean ACTIVhub - hub
Hub
USB 1.1
11 cm x 3.6 cm x 1.4 cm
35 g
1 year warranty
Hub
Enclosure Type
Desktop
Max Range Open Space
75 m
Frequency Band
2.4 GHz
USB 1.1
1 x USB
1 x USB cable - 1 m
UL, FCC
11 cm
3.6 cm
1.4 cm
35 g
Limited warranty - 1 year
50 °C
0 - 90%
