Your basket is empty
Promethean ActivBoard 378PRO 300 PRO Seri
Quicklinx: 68N7WS00 Mfr#: AB378PUK
Hurry, only 3 left in stock!
£1,216.67 ex VAT
£1,460.00 inc VAT
With built-in speakers, an integrated amplifier, and two USB ports ready to receive any peripheral, the ActivBoard 300 Pro is more than an interactive whiteboard; it's an interactive multimedia experience. Video and audio capability coupled with ActivBoard 300 Pro's Dual-User input and the power of included ActivInspire Professional Edition make media-rich teaching happen easily - creating a 360-degree educational environment where any lesson is possible and any topic comes vividly to life. The ActivBoard 300 Pro also features wireless connectivity through the ActivAir Radio Frequency system using the ActivHub (not included).
Promethean ActivBoard 378 Pro - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
187 cm 133 cm
24.5 kg
Movement Detection Technology
Electromagnetic
Low-glare surface
1 x USB cable - external - 5 m
Microsoft Windows Vista / XP, Apple MacOS X 10.4.11 or later, Ubuntu 8.04
3 years warranty
187 cm
133 cm
24.5 kg
Input Device
Wired
USB
Electromagnetic
Active Area
162.8 cm x 117.5 cm
Low-glare surface
1 x USB
Styluses (4 pcs)
UL, FCC
Limited warranty - 3 years
50 °C
68N7 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.17
68N7 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
68N7 C2G 2-Port USB 2.0 Manual Switch In Stock £18.78
68N7 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.11
68N7 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.18
68N7 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.20
68N7 C2G USB Superbooster Extender Kit In Stock £33.46
68N7 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £35.26
Brand: Promethean
Price Range Ex VAT: 1000 - 1500
