Your basket is empty
Promethean AB395Pro UK
Quicklinx: 7VFSWS00 Mfr#: AB395PUK
Teaching is quite an experience. Learning should be too. The ActivClassroom has always been all-encompassing. Now, it's an all-in-one interactive, collaborative, multimedia experience designed to capture the imagination of any type of learner - from the auditory to the visual to the kinaesthetic and everywhere between. The reason: the ActivBoard 300 Pro Range, a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. With built in dual-User capability and ActivInspire Professional Edition software included, teachers have access to tens of thousands of free lessons and resources at Promethean Planet.
Promethean ActivBoard 395 Pro - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
241 cm 133 cm
31 kg
Movement Detection Technology
Electromagnetic
Low-glare surface
1 x USB cable - external - 5 m
Microsoft Windows Vista / XP, Apple MacOS X 10.4.11 or later, Ubuntu 8.04
3 years warranty
241 cm
133 cm
31 kg
Input Device
Wired
USB
Electromagnetic
Active Area
217.2 cm x 117.5 cm
Low-glare surface
1 x USB
Styluses (4 pcs)
UL, FCC
Limited warranty - 3 years
50 °C
7VFS C2G 2m USB 2.0 A/B Cable - Black In Stock £3.03
7VFS C2G 5m USB 2.0 A/B Cable - Black In Stock £4.28
7VFS C2G 2-Port USB 2.0 Manual Switch In Stock £16.49
7VFS C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.53
7VFS C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
7VFS C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.20
