The ActivBoard 300 Pro Range is a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. Built in Dual-User capability and with ActivInspire Professional Edition software included means teachers have access to tens of thousands of free lessons and resources at www.PrometheanPlanet.com.
- Promethean ActivBoard 378 Pro - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- Projector - 1280 x 800
- 187 cm 133 cm
- 24.5 kg
- Movement Detection Technology
- Electromagnetic
- Movement Resolution
- 2730 ppi
- Built-in stereo speakers, low-glare surface
- Cables Included
- 1 x USB cable - external - 5 m
- OS Required
- Ubuntu 8.10, Ubuntu 9.04, Microsoft Windows Vista / XP / 7, Mandriva Linux, Ubuntu 8.04, Apple MacOS X 10.4.11 - 10.6.1, Ubuntu 9.10
- 3-year warranty
- 187 cm
- 133 cm
- 24.5 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- 2730 ppi
- Active Area
- 162.8 cm x 117.5 cm
Display
- Projector
- Colour Support
- 16.7 million colours
- Native Resolution
- 1280 x 800
- Image Brightness
- 2000 lumens
- Image Contrast Ratio
- 2000:1
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Wallmount brackets, 4 x ActivPen
- Cables Included
- UL, FCC
- Software Included
- ActivInspire Professional Edition
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - Pentium 4 - 1 GHz - RAM 512 MB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.1 RAM 512 MB - HD 3 GB
- Limited warranty - whiteboard - 3 years , Limited warranty - ActivPen - 1 year
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
