A small form-factor pluggable (SFP) Gigabit SX transceiver that provides a full-duplex Gigabit solution up to 550 m on multimode fiber.
- ProLabs J4858C-C - SFP (mini-GBIC) transceiver module - GigE, Fibre Channel
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- Max Transfer Distance
- 550 m
- 1.34 cm x 5.825 cm x 0.85 cm
- Designed For
- Aruba 2530, 2930F 24, 2930F 48, 5406, Switch 5400zl 24; HP Switch 2910al-24, Switch 2910al-48; HPE 1700, 1810, 1910, 20p 10/100/1000, 2610, 2810, 2910, 3500, 6120, 6200, 6600, Switch 1800-24, Switch 2900-24, Switch 2900-48, Switch 8212, Switch vl 4-port, Switch XL 10/100/1000, V1400, vl 20
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- Fibre Channel
- FC-PI-5
- 1.25 Gbps
- 850 nm
- 550 m
- IEEE 802.3, IEEE 802.3z
- 2 x Fibre Channel / Ethernet 1000Base-SX - LC
- Compatible Slots
- 1 x SFP (mini-GBIC)
- RoHS, Laser Class 1, EN 60825-1, MSA
- 1.34 cm
- 5.825 cm
- 0.85 cm
- 0 °C
- 70 °C
- Designed For
- Aruba 2530-24G, 2530-24G-PoE+, 2530-48G, 2530-48G-PoE+, 2530-48-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl, Switch 5400zl 24p Mini-GBIC Module , HP 9400sl 40-Port Mini-GBIC Module, EP Redundant Management Module, Switch 2510-24, Switch 2510-48, Switch 2510G-24, Switch 2510G-48, Switch 2610-24, Switch 2610-24/12-PWR, Switch 2610-24-PWR, Switch 2610-48, Switch 2610-48-PWR, Switch 2910al-24G-PWR, Switch 2910al-48G-PWR , HPE 1700-24 Switch, 1810-24 v2, 1810-24G Switch, 1810-8 v2, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 20p 10/100/1000 + 4p Mini-GBIC Module, 2610-24 Switch, 2610-24-PoE Switch, 2610-24-PPoE Switch, 2610-48 Switch, 2610-48-PoE Switch, 2810-24G Switch, 2810-48G Switch, 2910-24G al Switch, 2910-24G-PoE+ al Switch, 2910-48G al Switch, 2910-48G-PoE+ al Switch, 3500-24G-PoE yl Switch, 3500-48G-PoE yl Switch, 6120XG Blade Switch, 6200-24G-mGBIC yl Switch, 6600-24G, 6600-24G-4XG Switch, 6600-48G, 6600-48G-4XG Switch, Switch 1800-24G, Switch 2600-8-PWR, Switch 2626, Switch 2626-PWR, Switch 2650, Switch 2650-PWR, Switch 2824, Switch 2848, Switch 2900-24G, Switch 2900-48G, Switch 3400cl-24G, Switch 3400cl-48G, Switch 6108, Switch 8212zl, Switch fl 10-Port Mini-GBIC Interface Module, Switch gl 10/100/1000 Module, Switch gl Mini-GBIC Module, Switch vl 4-port Mini-GBIC Module, Switch XL 10/100/1000 Module, Switch xl Mini-GBIC Module, V1400-24G Switch, vl 20p Gig-T+ 4P SFP module switch
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
BL44 033840 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033842 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033843 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033844 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033845 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033846 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033847 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033848 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033849 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033850 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033851 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033852 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033853 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Ref:
BL44 033854 Condition: Customer return - item has been opened but is in excellent condition |
£3.33 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
