Prestigio RoadRunner CUBE Full HD WiFi Sony Sensor Dashcam Black
Quicklinx: D8R2WS00 Mfr#: PR-PCDVRR530WBK
Type: Dashboard camera
Video Input: USB 2.0
£41.25 ex VAT
£49.50 inc VAT
Never worry about the quality of recorded video Full HD definition of Prestigio Roadrunner CUBE camera ensures that every single detail will be visible and you can be confident about your safety on the road. If an accident occurs you will get all the evidence of your innocence.
  • Full HD video
  • Built-in Wi-Fi
    Pair your Prestigio Roadrunner CUBE with your smartphone via Wi-Fi and increase its possibilities: view, download or delete recorded images and video, update driving information.
  • Overheating protection system
    Prestigio understands that overheating can damage the battery or the whole device. That is why it implemented an overheating system.
Prestigio Roadrunner CUBE - dashboard camera
Dashboard camera - 1080p - widescreen
Memory Card Slot
SD card
Image Processor
MSC8328P
Sensors
G-sensor
Wireless Interface
Wi-Fi
Sensor Resolution
2.0 MP
Effective Sensor Resolution
Photo: 2.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Display
LCD display - 1.5"
Incident Detection
G-Sensor
Supported Battery
1 x Li-Polymer rechargeable battery - 150 mAh (included)
USB 2.0
4.5 cm x 4.4 cm x 4.5 cm
72 g
1-year warranty
Enclosure Colour
Camcorder Sensor Resolution
2.0 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
2.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.9"
Frame Rate (Max Resolution)
30 fps
Image Processor
MSC8328P
Sensors
G-sensor
Digital Video Format
H.264
Image Recording Format
JPEG
1920 x 1080
USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Wide-angle lens - wide angle
Focus Adjustment
Focus free
Max View Angle
140 degree(s)
Additional Features
Additional Features
Audio recording, built-in speaker, Motion Detection Technology, overheat protection
Dashboard Camera Features
Incident Detection
G-Sensor
Loop recording
Display
1.5" LCD display
Display Format
480 x 240
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (5 pin Micro-USB Type B)
Car power adapter, USB cable, adhesive mount
Body Material
Plastic, metal
Battery Type
Lithium polymer - integrated
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Memory Card Max Supported Size
32 GB
Video Capture
H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps
Limited warranty - 1 year
4.5 cm
4.4 cm
4.5 cm
72 g
45 °C
Brand: Prestigio
