Prestigio RoadRunner 585 Super HD 2" Screen Dashcam
Quicklinx: D8RQWS00 Mfr#: PR-PCDVRR585GPS
First-class technical specifications of the RoadRunner 585 and additional security features protect the driver's safety. With Super HD video and 16 MP photos you will see all the details, whilst Low Light Warning and Forward Car Movement Detection will guarantee additional support.
The video quality is excellent - Ambarella A7 chipset ensures Super HD resolution. The RoadRunner 585 captures every detail even in low light conditions thanks to HDR technology. A 2.0" screen is bright enough and has high resolution to playback video and to view photos clearly on it. A 160° viewing angle ensures you capture the wide field of view, whilst the 16 MP camera refines the picture quality.
The outstanding Forward Car Movement Detection feature enhances safety on the road by alerting the driver to movement detected in front of the car. In addition it is increased assistance when in front of a traffic light or pulling out of the car park. You will never forget to switch on the car headlights when it gets dark with Low Light Warning. The function warns you when it detects low light conditions.
Thanks to an enlightened glass lens you can achieve excellent quality video. G-sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording. The device features a progressive motion detection technology. In this mode the video shooting, starts only when detecting a new movement in the frame, allowing you to reserve the memory card for a longer video. This function might be very useful during the long-term parking.
  • Total support for safety on the road
  • Super HD video quality
  • Bright 2.0" screen
  • Capture details
  • Forward car movement detection
    This outstanding feature enhances safety on the road by alerting the driver to movement detected in front of the car. In addition it is increased assistance when in front of a traffic light or pulling out of the car park.
  • Low light warning
    You will never forget to switch on the car headlights when it gets dark - the function warns you when it detects low light conditions.
  • Enlightened glass optics
  • G-sensor for file protection
  • Motion detection
Prestigio Roadrunner 585 - dashboard camera
Dashboard camera - 1296p
Memory Card Slot
microSD card
Image Processor
Ambarella
Sensors
G-sensor
Sensor Resolution
4.0 MP
Effective Sensor Resolution
Photo: 4.0 MP
Max Video Resolution
2304 x 1296
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Display
LCD display - 2"
Incident Detection
G-Sensor
Supported Battery
Li-Polymer rechargeable battery - 180 mAh (included)
HDMI, USB 2.0
5.6 cm x 3 cm x 6.5 cm
60 g
1-year warranty
Enclosure Colour
Camcorder Sensor Resolution
4.0 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
4.0 MP
Camcorder Interpolated Photo Resolution
16.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/3"
Frame Rate (Max Resolution)
30 fps
Image Processor
Ambarella
Sensors
G-sensor
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
2304 x 1296
HDMI, USB 2.0
Exposure & White Balance
Exposure Modes
Programme, automatic
White Balance
Automatic, presets
Lens System
Wide-angle lens - wide angle
Focus Adjustment
Focus free
Max View Angle
160 degree(s)
Additional Features
Low Lux / Night Mode
Additional Features
Audio recording, built-in speaker, Motion Detection Technology
Dashboard Camera Features
Incident Detection
G-Sensor
Loop recording, parking mode, date and time stamp, WDR technology, Headlight Reminder, Forward Car Movement Detection
Display
2" LCD display
Display Format
960 x 240
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (mini-USB Type B) , HDMI output
Car power adapter, USB cable, suction cup mount
Body Material
Plastic
Battery Type
Lithium polymer - integrated
Run Time (Up To)
15 min
Details
Battery Life Details
Video recording - 0.25 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Included
No
Memory Card Max Supported Size
64 GB
Video Capture
H.264 - 1280 x 720 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 2304 x 1296 p - 30 fps
Limited warranty - 1 year
5.6 cm
3 cm
6.5 cm
60 g
45 °C
