First-class technical specifications of the RoadRunner 585 and additional security features protect the driver's safety. With Super HD video and 16 MP photos you will see all the details, whilst Low Light Warning and Forward Car Movement Detection will guarantee additional support.
The video quality is excellent - Ambarella A7 chipset ensures Super HD resolution. The RoadRunner 585 captures every detail even in low light conditions thanks to HDR technology. A 2.0" screen is bright enough and has high resolution to playback video and to view photos clearly on it. A 160° viewing angle ensures you capture the wide field of view, whilst the 16 MP camera refines the picture quality.
The outstanding Forward Car Movement Detection feature enhances safety on the road by alerting the driver to movement detected in front of the car. In addition it is increased assistance when in front of a traffic light or pulling out of the car park. You will never forget to switch on the car headlights when it gets dark with Low Light Warning. The function warns you when it detects low light conditions.
Thanks to an enlightened glass lens you can achieve excellent quality video. G-sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording. The device features a progressive motion detection technology. In this mode the video shooting, starts only when detecting a new movement in the frame, allowing you to reserve the memory card for a longer video. This function might be very useful during the long-term parking.
Total support for safety on the road
First-class technical specifications of the RoadRunner 585 and additional security features protect the driver's safety. With Super HD video and 16 MP photos you will see all the details, whilst Low Light Warning and Forward Car Movement Detection will guarantee additional support. -
Super HD video quality
The video quality is excellent - Ambarella A7 chipset ensures Super HD resolution. The RoadRunner 585 captures every detail even in low light conditions thanks to HDR technology. -
Bright 2.0" screen
A 2.0" screen is bright enough and has high resolution to playback video and to view photos clearly on it. -
Capture details
A 160° viewing angle ensures you capture the wide field of view, whilst the 16 MP camera refines the picture quality. -
Forward car movement detection
This outstanding feature enhances safety on the road by alerting the driver to movement detected in front of the car. In addition it is increased assistance when in front of a traffic light or pulling out of the car park. -
Low light warning
You will never forget to switch on the car headlights when it gets dark - the function warns you when it detects low light conditions. -
Enlightened glass optics
Thanks to an enlightened glass lens you can achieve excellent quality video. -
G-sensor for file protection
G-sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording. -
Motion detection
- Prestigio Roadrunner 585 - dashboard camera
- Product Type
- Dashboard camera - 1296p
- Memory Card Slot
- microSD card
- Image Processor
- Ambarella
- Sensors
- G-sensor
- Sensor Resolution
- 4.0 MP
- Effective Sensor Resolution
- Photo: 4.0 MP
- Max Video Resolution
- 2304 x 1296
- Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Display
- LCD display - 2"
- Incident Detection
- G-Sensor
- Supported Battery
- Li-Polymer rechargeable battery - 180 mAh (included)
- Interface
- HDMI, USB 2.0
- Black
- 5.6 cm x 3 cm x 6.5 cm
- 60 g
- 1-year warranty
- Product Type
- Enclosure Colour
- Black
- Camcorder Sensor Resolution
- 4.0 MP
- Sensor Qty
- 1 CMOS
- Effective Photo Resolution
- 4.0 MP
- Camcorder Interpolated Photo Resolution
- 16.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/3"
- Frame Rate (Max Resolution)
- 30 fps
- Image Processor
- Ambarella
- Sensors
- G-sensor
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 2304 x 1296
- Interface
- HDMI, USB 2.0
Exposure & White Balance
- Exposure Modes
- Programme, automatic
- White Balance
- Automatic, presets
Lens System
- Wide-angle lens - wide angle
- Focus Adjustment
- Focus free
- Max View Angle
- 160 degree(s)
Additional Features
- Low Lux / Night Mode
- Additional Features
- Audio recording, built-in speaker, Motion Detection Technology
Dashboard Camera Features
- G-Sensor
- Loop recording, parking mode, date and time stamp, WDR technology, Headlight Reminder, Forward Car Movement Detection
Display
- 2" LCD display
- Display Format
- 960 x 240
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 (mini-USB Type B) , HDMI output
- Included Accessories
- Car power adapter, USB cable, suction cup mount
- Body Material
- Plastic
- Battery Type
- Lithium polymer - integrated
- Run Time (Up To)
- 15 min
- Details
- Battery Life Details
- Video recording - 0.25 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 64 GB
- Video Capture
- H.264 - 1280 x 720 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 2304 x 1296 p - 30 fps
- Limited warranty - 1 year
- 5.6 cm
- 3 cm
- 6.5 cm
- 60 g
- 0 °C
- 45 °C
