Prestigio RoadRunner 565GPS HD DashCam
Quicklinx: BT6DWS00 Mfr#: PCDVRR565GPS
FUNCTIONALITY AND SAFETY ON ROAD!
This is a Video recorder which takes protection to a whole new level. It allows you to be safe on the road and receive warnings when unitentionally the vehicle is leaving or crossing its lane.
SUPER HD VIDEO QUALITY
Record highest quality Super HD videos with Ambarella A7 chipset, sensitive Aptina sensor, IS and WDR technology. Highly detailed videos can be used as evidence in legal action, and motor vehicle insurance claims to prove liability.
Warns and protects
RoadRunner 565 makes your trips more safe and protects from accidents that can occur because of negligence or due to somnolence. Video recorder will warn driver in case the vehicle is leaving or crossing its lane. (Lane Departure Warning System (LDWS)
Capture details with 10x zoom
An ultra wide viewing angle of 170 degrees and 10x digital zoom enables you to capture every detail in a nearly panoramic view.
Endless recording
Cyclic recording ensures that camera doesn’t stop recording in case the storage is full. Camera automatically overwrites the oldest files on the memory card, thus enabling it to record indefinitely.
256 MB internal memory allows to save recorded videos on device even without SD card.
Motion Detection
The device features a progressive motion detection technology - the video shooting starts only when detecting a new movement in the frame allowing you to save the card memory for a longer vide
G-Sensor for file protection!
G-Sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won’t be removed by loop recording.
Prestigio Roadrunner 565GPS - dashboard camera
Dashboard camera - 1296p
Memory Card Slot
microSD card
Image Processor
Ambarella
Sensors
G-sensor, motion sensor
Sensor Resolution
3.0 MP
Effective Sensor Resolution
Photo: 3.0 MP
Max Video Resolution
2304 x 1296
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Digital Zoom
10x
Image Stabiliser
Electronic
Display
LCD display - 2"
Real-Time Locations
GPS
Incident Detection
G-Sensor
Supported Battery
Li-ion rechargeable battery - 130 mAh (included)
Composite video/audio, HDMI, USB 2.0
9.7 cm x 4.2 cm x 4.2 cm
83 g
1-year warranty
Enclosure Colour
Camcorder Sensor Resolution
3.0 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
3.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/3"
Digital Zoom
10x
Image Processor
Ambarella
Image Stabiliser
Electronic
Navigation
GPS receiver
Sensors
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
2304 x 1296
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Max View Angle
170 degree(s)
Additional Features
Built-in Light
Additional Features
Built-in speaker, Wide Dynamic Range (WDR), Motion Detection Technology
Dashboard Camera Features
Real-Time Locations
GPS
Incident Detection
G-Sensor
Loop recording, motion sensor, Lane Departure Warning System, radar detector
Display
2" LCD display
Display Format
640 x 480
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , HDMI output , Composite video/audio output
Software
Software
Drivers & Utilities
Car power adapter, USB cable, suction cup mount
Battery Type
Lithium Ion - integrated
Details
Battery Life Details
Video recording - 0.27 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Video Capture
H.264 - 2304 x 1296 - 30 fps , H.264 - 1920 x 1080 - 30 fps
Limited warranty - 1 year
9.7 cm
4.2 cm
4.2 cm
83 g
45 °C
