Always be aware of the situation on the road with the Prestigio RoadRunner 525! It includes a sensor that automatically saves footage when it detects a collision and cyclic recording which will ensure that the recording goes on indefinitely. A bright screen ensures extra visibility for easy navigation and footage playback right away.
Full HD quality
The RoadRunner 525 records quality videos in Full HD with pure sound and clear images to capture full details of your trip. -
Extra visibility
A 3" screen provides instant video playback and makes the device efficient for adjusting video resolution, changing video duration for cyclic recording. -
Endless recording
Cyclic recording ensures that your camera doesn't stop recording when the storage is full. The camera automatically overwrites the oldest files on the memory card, thus enabling it to record indefinitely. -
G-sensor for file protection
G-sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording. -
Aesthetic design
A solid metal housing prevents the device from damages and its soft touch exterior coating feels great in your hand, in addition to providing high resistance to scratches.
- Prestigio Roadrunner 525 - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- microSD card
- Sensors
- G-sensor
- Sensor Resolution
- 2.0 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Display
- LCD display - 3"
- Incident Detection
- G-Sensor
- Supported Battery
- Li-Polymer rechargeable battery - 300 mAh (included)
- Interface
- USB 2.0
- Black
- 8.6 cm x 3.7 cm x 5 cm
- 117 g
- 1-year warranty
- Product Type
- Enclosure Colour
- Black
- Camcorder Sensor Resolution
- 2.0 MP
- Sensor Qty
- 1 CMOS
- Camcorder Interpolated Photo Resolution
- 5.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/5.8"
- Frame Rate (Max Resolution)
- 30 fps
- Sensors
- G-sensor
- Digital Video Format
- AVI, H.264
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- USB 2.0
Exposure & White Balance
- Exposure Modes
- Programme, automatic
- White Balance
- Automatic
Lens System
- Wide-angle lens - wide angle
- Focus Adjustment
- Focus free
- Max View Angle
- 120 degree(s)
Additional Features
- Additional Features
- Audio recording, built-in speaker, Motion Detection Technology
Dashboard Camera Features
- G-Sensor
- Loop recording, WDR technology
Display
- 3" LCD display
- Display Format
- 960 x 240
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 (mini-USB Type B)
- Included Accessories
- Car power adapter, suction cup mount
- Body Material
- Metal
- Battery Type
- Lithium polymer - manufacturer-specific
- Run Time (Up To)
- 10 min
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps
- Limited warranty - 1 year
- 8.6 cm
- 3.7 cm
- 5 cm
- 117 g
- 0 °C
- 45 °C
