Product
Prestigio RoadRunner 525 Full HD 3" Screen Dashcam
Quicklinx: D8QZWS00 Mfr#: PR-PCDVRR525
Always be aware of the situation on the road with the Prestigio RoadRunner 525! It includes a sensor that automatically saves footage when it detects a collision and cyclic recording which will ensure that the recording goes on indefinitely. A bright screen ensures extra visibility for easy navigation and footage playback right away.
  • Full HD quality
    The RoadRunner 525 records quality videos in Full HD with pure sound and clear images to capture full details of your trip.
  • Extra visibility
    A 3" screen provides instant video playback and makes the device efficient for adjusting video resolution, changing video duration for cyclic recording.
  • Endless recording
    Cyclic recording ensures that your camera doesn't stop recording when the storage is full. The camera automatically overwrites the oldest files on the memory card, thus enabling it to record indefinitely.
  • G-sensor for file protection
    G-sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording.
  • Aesthetic design
    A solid metal housing prevents the device from damages and its soft touch exterior coating feels great in your hand, in addition to providing high resistance to scratches.
Prestigio Roadrunner 525 - dashboard camera
Dashboard camera - 1080p - widescreen
Memory Card Slot
microSD card
Sensors
G-sensor
Sensor Resolution
2.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Display
LCD display - 3"
Incident Detection
G-Sensor
Supported Battery
1 x Li-Polymer rechargeable battery - 300 mAh (included)
USB 2.0
8.6 cm x 3.7 cm x 5 cm
117 g
1 year warranty
Enclosure Colour
Camcorder Sensor Resolution
2.0 MP
Sensor Qty
1 CMOS
Camcorder Interpolated Photo Resolution
5.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/5.8"
Frame Rate (Max Resolution)
30 fps
Sensors
G-sensor
Digital Video Format
AVI, H.264
Image Recording Format
JPEG
1920 x 1080
USB 2.0
Exposure & White Balance
Exposure Modes
Programme, automatic
White Balance
Automatic
Lens System
Wide-angle lens - wide angle
Focus Adjustment
Focus free
Max View Angle
120 degree(s)
Additional Features
Additional Features
Audio recording, built-in speaker, Motion Detection Technology
Dashboard Camera Features
Incident Detection
G-Sensor
Loop recording, WDR technology
Display
3" LCD display
Display Format
960 x 240
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (mini-USB Type B)
Car power adapter, suction cup mount
Body Material
Metal
Battery Type
Lithium polymer - manufacturer-specific
Run Time (Up To)
10 min
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Max Supported Size
32 GB
Video Capture
H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps
Limited warranty - 1 year
8.6 cm
3.7 cm
5 cm
117 g
45 °C
