Prestigio RoadRunner 506 is a compact and autonomous technical video solution for your safety on the road in all conditions. It records Full HD video and takes high resolution pictures (up to 12 MP) to show you in detail what is going on around.
VIDEO QUALITY:
Produces high quality videos in Full HD 1080p with pure sound and crystal clear images to see in detail what is going on around.
2.0" DISPLAY:
Playback videos and view photos on bright hi-resolution 2" TFT LCD display with easy to use controls.
MOTION DETECTION:
in this mode, video shooting starts only when detecting a new movement in the frame. Consequently, it allows you to save the memory card for a longer video.
MAGNETIC CRADLE:
Easy to install and remove device without causing any damage. The device is securely fixed into cradle due to high-powered magnets.
- Display Size
- 2.0" | 480x240 px
- Processor
- NT96223
- Video I Photo Resolution
- 1920x1080 25fps | 12 MP
- Image Sensor
- 2 MP CMOS | Samsung 5B3
- Lens | Viewing Angle | Zoom
- 4-Layer glass lens | 120° | 4x
- Video Codec
- MJPEG
- Video I Picture Format
- Memory | Expansion
- 128 MB | up to 32 GB (SDHC, MicroSD)
- Other features
- Motion Detection, G-sensor, Electronic Image Stabilization, Cyclic recording
- GPS sensor
- Optional (for GPS model)
- Microphone I Speaker
- Built-in
- USB 2.0
- Power Source
- Built in Re-chargeable battery (250mAh) or from Car Power Adaptor
- Battery life
- 20 mins
- Operation Temperature
- 0 °~ 45 °?
- Dimensions/weight
- 82x55x20 mm I 90 g
- In the box
- Magnetic Cradle, Car Charger, USB Cable, Quick Start Guide, Warranty Card
Display Size
- 2.0" | 480x240 px
- NT96223
Image Sensor
Video Codec
- MJPEG
Memory | Expansion
Other features
GPS sensor
- Built-in
- USB 2.0
Power Source
Battery life
- 20 mins
- 0 °~ 45 °?
Dimensions/weight
In the box
