The Prestigio RoadRunner 330i with improved NT96223 chipset records high quality Full HD videos and takes vivid pictures with high resolution (up to 12 MP). Thanks to motion detection technology, cyclic recording and G-sensor the device is your reliable companion that is able to capture even the smallest details of your trip.
Full HD video quality
High quality Full HD (1080p) video with pure sound and crystal clear images enables to view your journey in detail. -
Endless recording
Cyclic recording ensures that your camera doesn't stop recording when the storage is full. The camera automatically overwrites the oldest files on the memory card, thus enabling it to record indefinitely. -
Extra visibility
Playback captured video instantly on the 3-inch screen. It is not necessary to insert a memory card into an external device - prove your innocence in seconds whilst remaining on the road. -
Precise imaging
You will appreciate the high optical quality 12MP photo made with four-element sharp lens, and the improved chipset which ensure recording of all events without fail. -
G-Sensor for file protection
G-Sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording.
- Prestigio Roadrunner 330I - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- microSD card
- Image Processor
- NTK96223
- Sensors
- G-sensor
- Sensor Resolution
- 1.0 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Digital Zoom
- 4x
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery - 200 mAh (included)
- Interface
- USB 2.0
- Black
- 9 cm x 3.6 cm x 5.4 cm
- 66 g
- 1-year warranty
- Product Type
- Enclosure Colour
- Black
- Camcorder Sensor Resolution
- 1.0 MP
- Sensor Qty
- 1 CMOS
- Camcorder Interpolated Photo Resolution
- 12.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/4"
- Frame Rate (Max Resolution)
- 25 fps
- Digital Zoom
- 4x
- Image Processor
- NTK96223
- Sensors
- G-sensor
- Digital Video Format
- AVI, MJPEG
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- USB 2.0
Lens System
- Wide-angle lens - wide angle
- Focus Adjustment
- Focus free
- Max View Angle
- 120 degree(s)
Additional Features
- Low Lux / Night Mode
- Additional Features
- Audio recording, built-in speaker, Motion Detection Technology
Dashboard Camera Features
- Loop recording
Display
- 3" LCD display
- Display Format
- 960 x 240
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B)
- Included Accessories
- Car power adapter, suction cup mount
- Body Material
- Plastic
- Battery Type
- Lithium polymer - integrated
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- AVI - 1920 x 1080 p - 25 fps - interpolated , AVI - 1280 x 720 p - 30 fps
- Limited warranty - 1 year
- 9 cm
- 3.6 cm
- 5.4 cm
- 66 g
- 0 °C
- 45 °C
