GET EVIDENCE ON THE ROAD
Compact and affordable car video recorder with 1.5 inch LCD screen. The RoadRunner 133 records videos up to HD resolution, features cyclic recording and motion detection to provide additional safety when on the road. In addition it`s small weight makes it highly portable and almost invisible in the car.
HD QUALITY: The Camera records videos in up to HD resolution with pure sound and clear images, which captures every single detail of your trip
• BRIGHT 1.5-INCH TFT SCREEN: Easy to customize the image clarity, contrast and colour settings with a 1.5-inch LCD screen. Adjust the video recording quality as well as all additional parameters and operation modes with the user-friendly control panel
• MOTION DETECTION: in this mode, video shooting starts only when detecting a new movement in the frame. Consequently, it allows you to save the memory card for a longer video
• COMPACT SIZE: The Compact size and weight of only 44 g, makes the RoadRunner 133 highly portable and almost invisible in the car
• BEST VALUE FOR MONEY: Benefitting from the latest technology, high build quality and a stylish design at an extremely affordable price
- Prestigio Roadrunner - dashboard camera
- Product Type
- Dashboard camera - widescreen
- Memory Card Slot
- microSD card
- Focus Adjustment
- Focus free
- Display
- LCD display
- Interface
- USB 2.0
- Product Type
- Dashboard camera
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Interface
- USB 2.0
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Focus Adjustment
- Focus free
Display
- LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Battery Type
- Lithium Ion - integrated
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card
