The tweed like fabric on the outside combined with the soft touch floss on the inside and colored elastic band give it an original and trendy look. The original Universal Elastic System (U.E.S.) ensures the largest compatibility on the market.
- PORT COPENHAGEN Univ - protective cover for tablet
- Product Type
- Protective cover for tablet
- Screen Size Compatibility
- 8"
- 22.1 cm x 17.8 cm x 1.9 cm
- 222 g
- Material
- Tweed
- Purple
- Limited lifetime warranty
- 22.1 cm
- 17.8 cm
- 1.9 cm
- 222 g
- Material
- Tweed
- Purple
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 8"
- Closure Type
- Closure strap
- Inner Dimensions
- 21.3 cm x 15.4 cm x 1.3 cm
- Port cut-outs, adjustable viewing angles, soft inner lining, Universal Elastic System (UES)
- Cover Features
- Stand function
- Lifetime
