Polycom Soundstation 2 EX
Quicklinx: 3TCCWS00 Mfr#: 2200-16200-102
Type: Conference phone
Stock Status: Used Stock
£350.84 ex VAT
£421.00 inc VAT
The SoundStation2, Polycom's next generation conference phone, is redefining the standard for business-quality voice conferencing. With industry-leading full duplex for natural, simultaneous two-way conversation, the SoundStation2 will exceed your expectations in medium to small conference rooms. Delivering remarkable voice quality equal to the SoundStation Premier and a 50% increase in microphone sensitivity over the award-winning SoundStation, users can speak in a normal voice and be heard clearly up to ten feet away - making every call a more productive call.
Poly SoundStation2 EX - conference phone with caller ID
Conference phone with caller ID
Speakerphone
Yes (digital duplex)
Caller ID
Call Services
Caller ID, Call Hold
Display
LCD display - monochrome - Yes
1-year warranty
Conference phone
Phone Features
Call Services
Caller ID Type
Caller ID
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Function Buttons
Conference button, menu navigation keys, flash button, mute button
Volume Control
Additional Features
Noise reduction, PIN code, on-hook dialling
Phone Memory
Phone Directory Capacity
25 names & numbers
Display
Display Resolution
132 x 65 pixels
Backlit
Display Languages
English, German, French, Italian, Norwegian, Portuguese, Spanish
Audio line out / RCA , Cellular phone connection headset jack / sub-mini-phone 2.5mm , 2 x microphone jack
Phone line cable - 2.1 m , Power cable - 6.4 m
Power adapter
VCCI Class B ITE, ICES-003, FCC Part 15 B, FCC Part 68
Power adapter
Dimensions & Weight (Base)
31.1 cm
36.8 cm
6.4 cm
0.8 kg
Limited warranty - 1 year
Resources
The following resources are available for the Polycom Soundstation 2 EX
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 3TCC 041801
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £312.60
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Polycom
Price Range Ex VAT: 300 - 500
