Product
Brand
Polycom SoundPoint IP Colour Display Expansion Module
Quicklinx: 90ZRWS00 Mfr#: 2200-12770-025
The SoundPoint IP Color Expansion Module enhances telephone attendant productivity with a vibrant color user interface and advanced call handling capabilities
The SoundPoint IP Color Expansion Module for the SoundPoint IP 670 desktop phone is an optimal solution for telephone attendants – receptionists, administrative assistants, secretaries, and other "power users" who manage and monitor multiple simultaneous telephone calls on a daily basis. The SoundPoint IP Color Expansion Module augments the color user interface of the SoundPoint IP 670 phone with a high-resolution color display and 14 multifunctional line keys that can be set up as a line registration, call appearance, or a speed-dial, direct station select (DSS)/busy lamp field (BLF)1 key. The Color Expansion Module matches elegantly with the look and feel of the SoundPoint IP 670 phone.
Equipped with a high-performance attendant console, which is based on the SoundPoint IP 670 phone and up to three SoundPoint IP Color Expansion Modules, the telephone attendant can reduce the number of lost customer calls, shorten transaction times, and increase the accuracy of call routing by promptly accepting, accurately screening, efficiently dispatching and effortlessly monitoring calls.
The SoundPoint IP Color Expansion Module also provides an easy transition from traditional PBX features and functionality into the world of Voice over IP with its large color display, 14 illuminated multifunctional line keys, and a significantly augmented and pleasing call visualization experience similar to that on the SoundPoint IP 670 phone.
Polycom SoundPoint IP Color Expansion Module - key expansion module
Key expansion module
12.5 cm x 16 cm x 12.5 cm
0.6 kg
1 year warranty
SoundPoint IP 670
Display
LCD display
12.5 cm
16 cm
12.5 cm
0.6 kg
1 year
Polycom SoundPoint IP 670
