Your basket is empty
Polycom SoundPoint IP Backlit Expansion Module for SoundPoint IP 650
Quicklinx: 90ZLWS00 Mfr#: 2200-12750-025
This product augments the user interface of the SoundPoint IP 650 and creates together with a host phone a high-performance, productivity-enhancing solution for telephone attendants. It also simplifies management and monitoring of a high volume of simultaneous calls and provides an easy transition from traditional Key Systems to the features and functionality of Voice over IP.
Polycom SoundPoint IP Expansion Module - key expansion module
Key expansion module
12.5 cm x 16 cm x 12.5 cm
0.6 kg
1 year warranty
SoundPoint IP 601, IP 650
Display
LCD display
12.5 cm
16 cm
12.5 cm
0.6 kg
1 year
Polycom SoundPoint IP 601, IP 650
