Your basket is empty
Polycom SoundPoint IP 550 SIP 4 line IP desktop phones with HD voice
Quicklinx: 90ZBWS00 Mfr#: 2200-12550-025
The four-line SoundPoint IP 550 desktop phone delivers calls of unprecedented richness and clarity and supports a comprehensive range of cutting-edge features.
The SoundPoint IP 550 desktop phone features Polycom's revolutionary HD Voice technology that incorporates wideband audio for over twice the voice clarity; Polycom's patented Acoustic Clarity Technology for crystal-clear, noise- and echo-free sound, plus best-in-class system design for high-fidelity, faithful voice reproduction.
The SoundPoint IP 550 desktop phone delivers advanced features and capabilities, such as shared lines, BLF, presence, and buddy lists. The SoundPoint IP 550 phone also boasts an integrated XHTML micro-browser for productivity-enhancing Web-based applications. Add the support of four lines, a backlit, high-resolution, easy-to-read graphical display and flexible customizations options, and it becomes clear why the SoundPoint IP 550 is certain to meet the needs of the most demanding managers and professionals.
The SoundPoint IP 550 desktop phone is engineered to make installation, configuration, and upgrades as simple and efficient as possible. The phone's built-in IEEE 802.3af PoE circuitry and a dual-port Ethernet switch enable flexible deployment options and savings on cabling expenses.
Polycom SoundPoint IP 550 - VoIP phone
VoIP phone
Main Features
Integrated Ethernet switch
VoIP Protocols
SIP
Voice Codecs
G.722, G.729ab, G.711u, G.711a
Lines Supported
4 lines
Intercom
Speakerphone
Yes (digital duplex)
Caller ID
Call Services
Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Display
LCD display - monochrome
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
1 year warranty
VoIP phone
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Intercom
Speakerphone
Function Buttons
Speakerphone button, headset button, mute button, hold button, auto redial button
Volume Control
Ringer Control
Additional Functions
Call timer, Intercom
Additional Features
On-hook dialling
IP Telephony
Main Features
VoIP Protocols
SIP
Voice Codecs
Lines Supported
4 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, HTTP
Network Ports Qty
Voice Features
Voice activity detection (VAD), echo cancellation (ECN), HD Voice
Network Features
Network Address Translation (NAT)
Display
Display Location
Base
Display Resolution
320 x 160 pixels
Display Information
Date, time
Headset jack
Hearing Aid Compatible
Network cable
UL, C-Tick, VCCI Class B ITE, GOST, CISPR 22 Class B, cUL, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/NZS 60950-1, CCC, RoHS, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, ANATEL
Dimensions & Weight (Base)
26.5 cm
19 cm
15 cm
1.26 kg
Limited warranty - 1 year
