How do you make industry-leading products even better? By adding Polycom's convenient and easy-to-use accessories that help you to save time, be more productive, and add more enjoyment to the use of your conferencing products. Whether it's cables, headsets, or a protective carrying case for your voice conferencing products, Polycom makes it easy for you to find the accessories you need.
- Poly - microphone
- Product Type
- Microphone
- Packaged Quantity
- 2 (specifications are for single item)
- Recommended Use
- Conference
- Microphone
- External
- Controls
- Mute
- Packaged Quantity
- Product Type
- Microphone
- Recommended Use
- Conference
Microphone
- Connectivity Technology
- Wired
Remote Control
- Controls
- Mute
- Cable Details
- Microphone cable
