Poly Y Cable - Training Cord with Microphone Mute & Quick Disconnect
Quicklinx: 4RQGWS00 Mfr#: 27019-01
Stock Status: Used Stock
£18.51 ex VAT
£22.21 inc VAT
For Plantronics A22, E10, M12, P10, S20 CA40, P10, P10H
Ideal for listening in to calls for training and coaching purposes, this Adapter Trainer Cord with Microphone Mute Switch and Quick Disconnect Clamp will allow for supervised calls for maximum effectiveness. (4 pin Quick Disconnect/QD only)
Plantronics' mission is to enhance personal communication. By allowing you to be more productive, safe, and comfortable you'll notice a marked improvment in the clarity of your daily communications.
Poly Y Adapter Trainer - headset splitter
Cable
Headset splitter
Connector
Quick Disconnect
Connector (Second End)
2 x Quick Disconnect
Avaya M12LU/CM, M12LUCM; Headset Switcher MX10; P10 Series P10H; Poly A22, E10, M12, M22, MX10, P10, S20
Cable Type
Headset splitter
Connector
Quick Disconnect
Avaya M12LU/CM, M12LUCM , Plantronics Headset Switcher MX10 , Plantronics P10 Series P10H , Poly A22, E10, M12, M22, MX10, P10, S20
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 4RQG 040291
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £2.75
Ref: 4RQG 040292
Ref: 4RQG 040293
Ref: 4RQG 040294
Ref: 4RQG 040295
Ref: 4RQG 040296
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Poly
Price Range Ex VAT: 0 - 50
