For Plantronics A22, E10, M12, P10, S20 CA40, P10, P10H
Ideal for listening in to calls for training and coaching purposes, this Adapter Trainer Cord with Microphone Mute Switch and Quick Disconnect Clamp will allow for supervised calls for maximum effectiveness. (4 pin Quick Disconnect/QD only)
Plantronics' mission is to enhance personal communication. By allowing you to be more productive, safe, and comfortable you'll notice a marked improvment in the clarity of your daily communications.
- Poly Y Adapter Trainer - headset splitter
- Cable
- Headset splitter
- Connector
- Quick Disconnect
- Connector (Second End)
- 2 x Quick Disconnect
- Designed For
- Avaya M12LU/CM, M12LUCM; Headset Switcher MX10; P10 Series P10H; Poly A22, E10, M12, M22, MX10, P10, S20
- Cable Type
- Headset splitter
- Connector
- Quick Disconnect
- Designed For
- Avaya M12LU/CM, M12LUCM , Plantronics Headset Switcher MX10 , Plantronics P10 Series P10H , Poly A22, E10, M12, M22, MX10, P10, S20
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
4RQG 040294 Condition: Damaged stock - Item is new but has packaging damage |
£2.75 |
Ref:
4RQG 040295 Condition: Damaged stock - Item is new but has packaging damage |
£2.75 |
Ref:
4RQG 040296 Condition: Damaged stock - Item is new but has packaging damage |
£2.75 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
