Poly Voyager Focus 2 UC Headset
Quicklinx: G9VYWS00 Mfr#: 213727-01
Recommended Use: Computer, Phone, Phone
Connectivity: Wired, Wireless
Earcover : Binaural
Hurry, only 1 left in stock!
£169.79 ex VAT
£203.74 inc VAT
We couldn't build a wall around you to block out background noise, so we did the next best thing: created a "focus zone" with the new Voyager Focus 2 headset. All you hear is your call with three levels of hybrid active noise canceling (ANC). All they hear is you with our pro-grade microphones using Poly Acoustic Fence technology. It's all the Poly next-level engineering you expect with the wear-it-all-day comfort you need. Connect to a computer with the included BT700 USB-A adapter and to a mobile via Bluetooth v5.1. Keep your headset fully charged at all times using a desktop charging stand.
  • Get great sound and block out noise
    The right level of active noise canceling (ANC), designed for the office, makes for a distraction-free call. It's not about unnatural and excessive noise blocking - it's about the right balance for audio comfort. Pair this with excellent sound for voices and you get a great experience.
  • Connect with ease
    Offering seamless connectivity to your PC or smartphone, the Voyager Focus UC is ready to work the way you do. With up to 98ft/30m of wireless range, enjoy mobility while calls and music stay crystal clear, whether you're at your desk, in the conference room or in the kitchen.
  • Use smart control of mute
    Control your conversations with mute and built-in smart sensors. Easily mute/un-mute with the touch of a button, or simply by taking the headset off and putting it back on. If you try to talk while your mic is muted, the Dynamic Mute Alert will give you an audible reminder.
  • Enjoy music in stereo
    When it's time to crank up your music, the Voyager UC delivers rich bass, crisp highs, and natural mid-tones in stereo. It pauses the music whenever you take the headset off, and resumes play when you put it on. And thanks to a smart mic boom, the volume and track controls adjust automatically.
  • Customize the settings to make it yours
    Choose the settings to customize your headset with Hub Desktop. Select language preference, feature settings and keep your device up-to-date with the latest firmware. For the IT team, Plantronics Manager Pro provides remote management, headset inventory and usage monitoring.
Poly Voyager Focus 2 UC - headset - with charging stand
Headset - Bluetooth - wireless, wired - USB-A
Recommended Use
Phone, computer
Additional Functions
SoundGuard DIGITAL
Headphones Form Factor
On-ear
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, power on/off, answer/end, ANC mode
Software Certification
Zoom Certified
Compatible Software
Cisco WebEx, MiCollab Client, Microsoft Teams, Zoom, Skype for Business
Bundled with
Charging stand
SoundGuard DIGITAL
175 g
Recommended Use
Phone, computer
Max Operating Distance
50 m
Bundled with
Charging stand
Audio Output
On-ear
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Advanced Hybrid Active Noise Cancellation
Microphone
Boom
Remote Control
Controls
Carrying case, charging cable, Bluetooth USB-A adapter
Zoom Certified
Compatible Software
Headset battery rechargeable - Lithium Ion
560 mAh
Run Time (Up To)
40 hour(s)
Run Time Details
Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 19 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
Standby Time
30 days
Recharge Time
2 hour(s)
Recommended Use: Phone
Connectivity: Wired
Connectivity: Wireless
Earcover : Binaural
Brand: Poly
