Working in and out of the office? We've got you covered. The Voyager 5200 headset provides professional-grade sound, no matter where you take the call. Now you can thrive in any environment on any of your devices, with versatile connectivity and Bluetooth technology.
Four-mic noise cancelling
Cutting edge noise cancelling technology eliminates background noise, so your voice always sounds clear. Four-mic array and our adaptive Digital Signal Processors (DSP) work together to cancel disruptive background noise like traffic or crowds. -
Take the call anywhere
Six layers of our unique WindSmart technology detect wind direction and respond accordingly so your voice comes through clearly – especially outdoors. -
High-quality audio
Supports HD Voice over wideband networks and devices to enhance speech quality, so your caller clearly hears and understands you. -
Smart sensor technology
Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off. -
Manage your calls using voice commands
Announces the names of incoming callers and waits for you to say "Answer" or "Ignore", allowing you to manage your calls using voice commands.
- Poly Voyager 5200 - headset
- Product Type
- Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
- Compatibility
- Windows, Mac
- Recommended Use
- Portable electronics, computer
- Additional Functions
- DSP
- Black
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Audio Specifications
- Frequency Response 100 - 20000 Hz - Sensitivity 90 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional, MEMS-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume control, on/off
- Intelligent Assistant
- Siri, Google Assistant
- Software Certification
- Certified for Skype for Business, Certified for Microsoft Teams, Zoom Certified, Cisco Jabber Certified, Avaya Certified, Works With Chromebook Certified
- Product Type
- Series
- Voyager 5200 series
- Compatibility
- Windows, Mac
- DSP
- 9.1 cm
- 5.3 cm
- 1.5 cm
- 20 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Voice alerts, 280° rotatable microphone
- Protection
- Sweat-proof
- Max Operating Distance
- 30 m
Audio Output
- In-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Equaliser
- 20 bands
- Active Noise Cancelling Technology
- WindSmart technology
- 100 - 20000 Hz
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 13.6 mm
- Digital signal processing, Smart Sensor Technology, echo cancelation, sidetone detection, SoundGuard Technology
Microphone
- Boom
- Sensitivity
- -38 dBV/Pascal
- 100 - 6800 Hz
- Noise Cancelling
Remote Control
- Controls
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Software Included
- Poly Lens
- Included Accessories
- 3 ear tips (small, medium, large), micro-USB charging cable, USB-A to microUSB cable
- Cable Details
- Micro-USB to USB-A cable - detachable
- Supported Host Device OS
- Windows, macOS
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 122 mAh
- Run Time (Up To)
- 7 hours
- Standby Time
- 9 days
- Recharge Time
- 1.6 hours
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £12.86 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
