Brand
Poly Studio P5 kit with Voyager 4220 UC
Quicklinx: G6FBWS00 Mfr#: 2200-87140-025
£193.55 ex VAT
£232.26 inc VAT
The Poly Studio P5 Kit with Voyager 4220 UC has everything you need for professional video conferencing with the flexibility of Bluetooth wireless audio. It includes a webcam and Bluetooth stereo headset all in one package that's easy to set up. Exceptional camera optics are fine-tuned so you always come across clearly with a powerful, professional-quality image. The wireless headset lets you hear and be heard clearly and easily switch from your PC or Mac to your mobile phone. For IT, the single-box design simplifies ordering and deployment, while Poly Lens cloud management provides robust tools to manage and track devices from anywhere.
  • Everything you need
    Packaged together as one, the Poly Studio P5 Kit is super-simple to setup and lets you choose the audio device that best suits how and where you work.
  • Pro-grade camera optics
    Automatic low-light compensation and brilliant colors make you look your best, without being left in the dark. The 1080p resolution with 4x digital zoom camera puts the focus on you, right where it belongs.
  • Move and groove
    The Poly Studio P5 Kit with Voyager 4220 UC includes a professional webcam and wireless headset with crisp stereo audio and noise cancelling dual headset mics.
Poly Studio P5 - webcam - with Poly Voyager 4220 UC Headset
Webcam
Bundled with
Audio
Yes: built-in directional microphone
Camera Mount Type
Tripod mount
3.77 cm x 3.4 cm x 6.2 cm
68 g
Wired
Camera
Video Modes
720p, 1080p
Focus Adjustment
Automatic
USB 2.0
USB cable - integrated
ePTZ, privacy shutter, Low Light Compensation (LLC)
Environmental Parameters (operating)
0 °C - 40 °C; 5 - 95% (non-condensing) relative humidity
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
3.77 cm
3.4 cm
6.2 cm
68 g
Worldwide
Bundled with
Camera
Video Modes
720p, 1080p
Digital Zoom
4
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
80
Computer Interface
USB 2.0
Ports
USB - 4 pin USB Type A
Monitor mount
Plug and Play
Apple MacOS X 10.7 or later, Windows 8.1, Windows 10
Relative Humidity (operating)
Brand: Poly
