Poly Studio P15, 4K USB All In One - UK
Quicklinx: G6FFWS00 Mfr#: 2200-69370-102
£230.58 ex VAT
£276.69 inc VAT
The Poly Studio P15 personal video bar gives you everything you need to look and sound your best on video calls in one sleek device. Exceptional optics and a high-performance 4K image sensor bring out your inner star, and automatic camera framing ensures you're always seen without staying glued to your chair. A powerful speaker and microphone array deliver rich clear audio, while NoiseBlockAI and Acoustic Fence technology keeps out distracting sounds. For IT, Poly Lens cloud management provides robust tools to manage and track devices from anywhere. Feel like you're there even when you can't be with Poly Studio P15.
  • Look amazing, be amazing
    Stay centered on camera without staying glued to your chair with automatic camera framing. When you're able to move, your energy stays up. When your energy is up, you're able to keep you audience engaged. With the automatic camera framing in the Poly Studio P15 you can go where the moment takes you but still stay in the spotlight.
  • Get ready for your closeup
    The Poly Studio P15 personal video bar gives you everything you need in one sleek device to look and sound your best on video calls. Exceptional optics and a high-performance 4K image sensor bring out your inner star.
  • Smart sound that makes you sound smart
    Make fuzzy-sounding audio and "say-again" moments history with acoustic innovation from Poly - the people who put the first headset on the moon. The integrated speaker features acoustic suspension with a passive radiator for rich sound, while the advanced multi-microphone array follows your motion to keep your voice coming through clearly.
  • Keep the good sound. Block the bad
    Wherever you work you're probably surrounded by all kinds of noise - coworkers yakking near the water cooler, barking dogs, your toddler's emergency, you name it. Prevent distracting noises and side conversations from interrupting your meetings with NoiseBlockAI and Acoustic Fence technology. Interruptions avoided, embarrassment averted.
  • The freedom to work how you want
    There's nothing to learn. The Poly Studio P15 works with the video apps you already know. A simple USB connection to your PC or Mac will transform your video conferencing experience.
Poly Studio P15 - webcam
Webcam
Audio
Yes: built-in speaker, beam-forming microphone array
Camera Mount Type
Tripod mount
42.5 cm x 7.8 cm x 6.5 cm
682 g
Wired
Camera
Video Modes
720p, 1080p, 2160p, 4K
USB
Software Certification
Zoom Certified, Certified for Microsoft Teams
USB-C cable
Voltage
DC 12 V
Privacy shutter, Low Light Compensation (LLC), auto-framing, Acoustic Echo Cancellation (AEC), background noise reduction, Poly NoiseBlockAI technology, Poly Acoustic Fence technology
Environmental Parameters (operating)
0 °C - 40 °C; 5 - 95% (non-condensing) relative humidity
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
42.5 cm
7.8 cm
6.5 cm
682 g
United Kingdom
Camera
Video Modes
Digital Zoom
4
Lens Construction
Diagonal Field of View (degree)
90
Computer Interface
USB
Ports
USB 3.0 - Type C , 2 x USB 2.0 - 4 pin USB Type A
Monitor mount
USB-C cable
Plug and Play
Power Requirements
DC 12 V - 3 A
Power adapter - external
Windows 8.1, Windows 10, Apple MacOS X 10.10 or later
Relative Humidity (operating)
Brand: Poly
