The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
One headset for all your devices
Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution. -
Connect and communicate more effectively
The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. One-touch controls - such as call answer/end, volume up/down and mute - let you manage calls from any connected device within roaming range. Convenient voice prompts notify you of mute status, roaming range limit, and more.
- Poly Savi 8220 UC - Standard - wireless headset system
- Product Type
- Wireless headset system - DECT 6.0 - wireless
- Recommended Use
- Phone, computer
- Additional Functions
- SoundGuard DIGITAL
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT 6.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Controls
- Volume, power on/off, answer/end, ANC on/off
- Product Type
- 160 g
- Recommended Use
- Phone, computer
- Max Operating Distance
- 180 m
Audio Output
- On-ear
- Wireless
- DECT 6.0
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 118 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
Microphone
- Boom
- Form Factor
- Headset microphone
- 100 - 6800 Hz
- Max Sound Pressure
- 112 dB
Remote Control
- Controls
- Included Accessories
- DECT USB dongle
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 700 mAh
- Run Time (Up To)
- 13 hour(s)
- Standby Time
- 50 hours
- Recharge Time
- 3 hour(s)
