The Savi 8200 series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 series headsets for training or call resolution.
Multi-device connectivity
Switch seamlessly between PC, mobile and desk phone. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 series headsets for training or call resolution. -
The sound of excellence
Savi 8200 series delivers enterprise-grade DECT audio for a premium listening experience. Savi 8210 is ideal when you need to be dialed into calls but also hear what's going on around you.
- Poly Savi 8210 UC - Standard - headset
- Product Type
- Headset - DECT 6.0 - wireless
- Recommended Use
- Phone, computer
- Additional Functions
- SoundGuard DIGITAL
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT 6.0
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Microphone Noise Cancelling
- Controls
- Mute, volume, on/off, answer/end
- Product Type
- 115 g
- Recommended Use
- Phone, computer
- Max Operating Distance
- 180 m
Audio Output
- On-ear
- Wireless
- DECT 6.0
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- Sensitivity
- 118 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
Microphone
- Boom
- Form Factor
- Headset microphone
- Mono
- 100 - 6800 Hz
- Max Sound Pressure
- 112 dB
- Noise Cancelling
Remote Control
- Controls
- Included Accessories
- DECT USB dongle
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 490 mAh
- Run Time (Up To)
- 13 hour(s)
- Standby Time
- 50 hours
- Recharge Time
- 3 hour(s)
