Keep the conversation going whenever, wherever – at work. Built for on-site employees the Poly Rove wireless IP phone solution delivers the sweet freedom to move and the flexibility to scale as you grow. Dropped phone? No problem. You're covered with ruggedized IP65, dust-tight, and water-resistant technology. Protection doesn't stop there. Built to stay cleaner for longer with Microban antimicrobial product protection. And guard your most critical conversations with DECT technology. We've got you covered. Built to last. Built to scale. Never miss a call. Communicate hands-free with a Poly headset using the 3.5mm connection.
Integrated microban antimicrobial protection
Rest assured that your devices, enhanced with Microban antimicrobial product protection, stay cleaner, fresher and more durable for longer. Protection that lasts the life of the product, actively reducing the growth of bacteria 24 hours a day 7 days a week. -
Guard your most critical conversations
Conversations are safe and secure with DECT wireless security. And it doesn't stop there - maintain DECT encryption even when you add a base or repeater to your solution. -
Ruggedized protection with pro-grade quality
Built to withstand all that life throws at it. Drops. Dust. Water. The ruggedized handsets are drop proof up to 6.6 ft/2 m and IP65 dust-tight and water resistant. Your investment will go the distance. -
Monitor, manage, and maintain
With Poly cloud management software, you'll be smarter. And management will be happier. Monitor, manage and maintain devices securely from the cloud with PDMS-SP software. And you can integrate the APIs into your business workflow no matter what platform you use.
- Poly Rove 30 - cordless extension handset with caller ID/call waiting - 3-way call capability
- Product Type
- Cordless extension handset with caller ID/call waiting
- Total Number of Wireless Handsets
- 1
- Cordless Phone Standard
- DECT
- Call Services
- Caller ID, Call Forwarding, Call Hold, Enhanced Call Park
- Display
- LCD display - colour - Yes
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Product Type
- 1
- Shipping Weight
- 365 g
- Body Material
- Ruggedised
- Protection
- Water-resistant, drop-resistant, IP65, dust-proof, Microban antimicrobial protection
Phone Features
- DECT
- Call Services
- Caller ID Type
- Caller ID/call waiting
- Dialer Location
- Handset
- Conference Call Capability
- 3-way
- Programmable Buttons Qty
- 4
- Ring Tones
- 20
- Indicators
- Message waiting indicator
- Additional Functions
- Intercom, redial, Do Not Disturb (DND), push to talk (PTT), OTA (Over the Air) upgrade
IP Telephony
- Voice Features
- Acoustic echo cancellation (AEC)
Display
- Display Location
- Handset
- Diagonal Size
- 2.4"
- Display Resolution
- 320 x 240 pixels
- Colour Depth
- 16-bit (65000 colours)
- Backlit
- Display Languages
- Danish, Czech, Slovenian, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Serbian, UK English, US English
- Connections
- Headset jack / mini-phone 3.5mm
- Hearing Aid Compatible
- Included Accessories
- Belt clip, power adapter, charging cradle
- ENERGY STAR Certified
- Capacity
- 1100 mAh
- Technology
- Rechargeable - Lithium Ion
- Talk Time
- Up to 1080 min
- Standby Time
- 300 h
Dimensions & Weight (Handset)
- 168 g
- Shipping Width
- 17.6 cm
- Shipping Depth
- 16.3 cm
- Shipping Height
- 4.4 cm
- Shipping Weight
- 365 g
- Limited warranty - 1 year
