Poly Plantronics Voyager Legend CS Wireless Headset for Deskphone & Mobile Wireless (with HL10 Lifter)
Quicklinx: 9295WS00 Mfr#: 88863-22
Recommended Use: Portable electronics
Connectivity: Wireless
Earcover : Monaural
£134.68 ex VAT
£161.61 inc VAT
You work in the office, on the drive home, even at home. For your flexible work style, the Voyager Legend CS was designed to move with you throughout your day. Its intuitive Smart Sensor technology lets you answer calls simply by placing it on your ear and you can always count on crystal clear audio with noise canceling technology that blocks out nearby voices, car horns, even wind. Enjoy simple call management and outstanding audio from your mobile phone on the road to your desk phone in the office, and everywhere in between.
  • The office headset designed to go mobile
    You work in the office, on the drive home, even at home. For your flexible work style, the Voyager Legend CS was designed to move with you throughout your day. Its intuitive Smart Sensor technology lets you answer calls simply by placing it on your ear and you can always count on crystal clear audio with noise canceling technology that blocks out nearby voices, car horns, even wind. Connect to your desk phone. Connect to your mobile. Work better on both.
  • Outstanding audio quality
    Hear and be heard clearly wherever you take your calls. The headset features a precision tuned triple-mic with enhanced DSP for superior noise cancellation, while advanced WindSmart technology provides three layers of wind protection. Integrated A2DP lets you listen to streaming media from your mobile phone or tablet.
  • Excellent technology
    Smart Sensor technology creates a seamless and intuitive user experience by automatically answering calls simply by placing on your ear and automatically transferring calls between your mobile phone and headset.
  • Voice alerts and commands
    Voice command menu lets you use your voice to answer calls, check battery level, redial, put headset in pairing mode and for a host of other headset commands.
Poly - Plantronics Voyager Legend CS - headset - with Plantronics HL10
Headset - Bluetooth - wireless
Recommended Use
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 3.0 EDR
Sound Output Mode
Mono
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Answer/end
Environmental Standards
TCO Certified Headsets 3
Bundled with
Plantronics HL10 Handset Lifter
18 g
Recommended Use
Max Operating Distance
10 m
Bundled with
Audio Output
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Microphone
Boom
Mono
Remote Control
Controls
Answer/end
Wireless Link
Transmission Range
10 m
Connector Type
Bluetooth
TCO Certified
Headset battery rechargeable
Run Time (Up To)
7 hours
Standby Time
264 hours
9295 Poly Plantronics HL10 lifter for SAVI Office Range In Stock £24.22
9295 Poly Plantronics APS-11 Electronic Hookswitch Cable In Stock £30.05
9295 Poly Plantronics APV-66 Electronic Hook Switch In Stock £25.25
9295 Poly Plantronics APN-91 NEC EHS In Stock £18.99
9295 Poly Plantronics APU-72 Electronic Hook Switch In Stock £22.28
9295 Poly Plantronics APC-82 Electronic Hook Switch Adapter for Cisco In Stock £21.04
Earcover : Monaural
Brand: Poly
