Plantronics offers products for the computer and mobile market segments, specializing in telephone products, such as amplified telephone headsets, telephones for hearing-impaired users and noise-canceling headsets, handsets for use in high-noise environments and value packs. As the world's leading designer, manufacturer and marketer of lightweight communications headset products, Plantronics produces a great deal of accessories for its versatile headsets.
One replacement voice tube for Encore, Tristar, and SupraPlus series. Clear color.
- Poly - voice tube for headset
- Product Type
- Voice tube
- Intended For
- Headset
- Clear
- Designed For
- DuoPro; DuoSet; Encore; TriStar
- Product Type
- Voice tube
- Intended For
- Headset
- Clear
- Designed For
- Poly - Plantronics DuoPro , Poly - Plantronics DuoSet , Poly - Plantronics Encore , Poly - Plantronics TriStar
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CSF6 041125 Condition: This item is new and unused. The packaging has been opened. |
£0.18 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
