The Plantronics SupraPlus headset series has been trusted by enterprises around the world for years, and continues to set the standard for durable, lightweight corded headsets, designed for contact center and office professionals.
Business-critical reliability and comfort
SupraPlus not only meets or exceeds all specifications set by the existing world-class professional headsets, but this series of headsets also delivers superior all-day, every-day comfort and reliability. -
Experience full wideband audio
The entire SupraPlus series takes advantage of wideband VoIP technologies. The extended noise-canceling boom features wideband receivers to deliver improved speech clarity and life-like fidelity - which helps to decrease listening errors, repeats and listener fatigue. -
Comfort, style and, lightweight design
The light flexible cable and comfortable headband design, as well as the bendable microphone boom, work to enhance audio quality and the user experience. -
Plantronics compatibility
With Plantronics Quick Disconnect SupraPlus works with all Plantronics audio processors and USB-to-headset adapters. Direct connect solutions are also available for headset-ready phones and agent consoles, providing connection flexibility for your diverse working environment.
- Poly SupraPlus HW361/A - headset
- Product Type
- Headset - wired
- Recommended Use
- Phone
- Silver
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Microphone
- Boom
- Product Type
- Headset - wired
- 74 g
- Silver
- Recommended Use
- Phone
Audio Output
- On-ear
- Wired
Microphone
- Boom
- Connector Type
- Headset (Quick Disconnect)
- Cable Details
- Headset cable
Poly Proshare connector cable | In Stock | £22.62 |
Poly Plantronics PLA HIS-1 Adapter Cable (Wideband) | In Stock | £28.49 |
Poly Plantronics PLA HIC-1 Adapter Cable (Narrowband) | In Stock | £17.05 |
