The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
One headset for all your devices
Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution. -
Connect and communicate more effectively
The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. One-touch controls - such as call answer/end, volume up/down and mute - let you manage calls from any connected device within roaming range. Convenient voice prompts notify you of mute status, roaming range limit, and more.
- Poly Savi 8240 UC, Microsoft - headset
- Product Type
- Headset - DECT 6.0 / Bluetooth - wireless
- Recommended Use
- Phone, computer
- Headphones Form Factor
- In-ear - convertible
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Controls
- Mute, volume, on/off, answer/end
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Series
- 8200 Series
- 115 g
- Recommended Use
- Phone, computer
- SweatGuard Technology
- Max Operating Distance
- 180 m
Audio Output
- Wireless
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- Sensitivity
- 118 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
- SoundGuard DIGITAL Technology
Microphone
- Boom
- 100 - 6800 Hz
- Max Sound Pressure
- 112 dB
Remote Control
- Controls
- Included Accessories
- DECT USB dongle
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 490 mAh
- Run Time (Up To)
- 13 hour(s)
- Standby Time
- 50 hours
- Recharge Time
- 3 hour(s)
