Poly Plantronics Elara 60 Series for Voyager
Quicklinx: FCKCWS00 Mfr#: 212952-409
MOBILE TO DESK MADE EASY
Today’s workers need mobile freedom and desktop convenience. The Poly Elara 60 Series gives them the best of both worlds. It’s a desktop mobile phone station that keeps your mobile charged, makes it easy to move a call from your mobile and back again, and lets you join Microsoft Teams meetings with a single touch. Headset and speakerphone options offer customized comfort plus flexibility.
  • Turn your smartphone into a desktop collaboration tool
    The call doesn't end when you get to the office - it gets better. Now you can seamlessly transition the call to the Poly Elara 60 Series mobile phone station and make collaboration happen your way, using headset, speakerphone and handset options.
  • Stay connected and charged
    Personalize your communications choices with a range of enterprise-grade headset, speakerphone and handset options to manage your mobile calls. And while you're on the call, your Android or iOS smartphone automatically charges with wired or optional multi-coil wireless charging.
  • Deployment is simple
    With Poly Elara 60 Series, there is no service provisioning and no extra wires. Just plug it into a power outlet, pair your mobile phone and you're done. Deployment throughout the enterprise is easy, saving time and money and enabling greater simplicity and freedom - for you and your users.
Poly Elara 60 WS - without headset - speakerphone
Speakerphone - Bluetooth - wireless
Rest of World
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2 EDR
Audio Specifications
Frequency Response 100 - 6800 Hz - Sensitivity 81.5 dB
Impedance
4 Ohm
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end, play/pause, next/previous track
Software Certification
Certified for Microsoft Teams
Series
60 Series
Dimensions & Weight Details
650 g
LCD display, Kensington lock secure slot
Max Operating Distance
9.1 m
Rest of World
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Frequency Response
100 - 6800 Hz
Sensitivity
81.5 dB
Impedance
4 Ohm
Diaphragm
50 mm
Microphone
Omni-directional
Sensitivity
-16 dBV/Pascal
Frequency Response
100 - 6800 Hz
Remote Control
Controls
Power adapter
AC 120/230 V
