Poly Plantronics DA80 Audio Processor - USB/QD w/inline controls
Quicklinx: B8KXWS00 Mfr#: 201852-02#Duplicated use F4VG
The Plantronics DA80 is a high-performance USB audio processor for analog headsets with high quality audio and one-touch call, mute and volume control. Plantronics software takes the DA80 one step further by revealing insights which can be used to enable more effective operations - it can detect when the headset is disconnected and will automatically activate screen locking for security compliance, it can report on call events, and more.
Poly DA80 - sound card
Sound card
Enclosure Type
External
Interface Type
USB
Hardware Controls And Indicators
Volume control, mute button
EncorePro HW510, HW510V, HW515, HW520, HW520V, HW525, HW530, HW535, HW540, HW545, HW710, HW715, HW720, HW725
Sound card
External
Interface Type
USB
Audio Output
Upgradeable firmware
1 x USB - 4 pin USB Type A , 1 x headset - Quick Disconnect
1 x USB cable
Poly EncorePro HW510, HW510V, HW515, HW520, HW520V, HW525, HW530, HW535, HW540, HW545, HW710, HW715, HW720, HW725
