Poly Plantronics Blackwire C5210 USB-A Bulk Wired Headset
Quicklinx: DY1MWS00 Mfr#: 207577-03
Recommended Use: Computer, Portable electronics, Conference
Connectivity: Wired
Earcover : Monaural
29 in stock
£65.61 ex VAT
£78.73 inc VAT
The Blackwire 5200 series fits your busy workday. Easy to use, it's so comfortable, you'll be able to wear it all day.
  • All-day comfort and universal connectivity
    When you need to wear a headset all day, the Blackwire 5200 series has you covered in great comfort. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls.
  • Outstanding audio quality for better productivity
    Today's workplace can be noisy and filled with distractions. With the Blackwire 5200 series, you'll be able to hear and be heard more clearly, enjoy conversation privacy and be more productive. That's because soft, conforming ear cushions provide passive noise canceling, while a precisely tuned microphone masks nearby conversations.
  • A headset that works the way you do
    Adjust the headset to fit the way you work. Dedicated, customizable mute settings allow you to take calls confidently, ensuring you're always heard. Set the language for voice alerts, and you're in even greater control of your conversation.
Poly - Plantronics Blackwire C5210 USB-A - Bulk - headset
Headset - wired - USB, 3.5 mm jack
Recommended Use
Portable electronics, computer, conference - communication
Additional Functions
DSP
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Series
5200 Series
DSP
Dimensions & Weight Details
125.4 g
Headband Material
Cushioned metal
Earpad Material
Leatherette
Recommended Use
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Mono
In-Cord Volume Control
Adjustable Headband
SoundGuard Technology, voice alerts
Microphone
Boom
Headset microphone
Frequency Response
100 - 8000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headset (mini-phone stereo 3.5 mm 4-pole)
Carrying case, wired remote control
Cable Details
Headset cable
Recommended Use: Portable electronics
Recommended Use: Conference
Connectivity: Wired
Earcover : Monaural
Brand: Poly
Stock Status: In stock
