Poly P5 1080P HD Webcam
Quicklinx: HK6MWS00 Mfr#: 76U43AA
12 In Stock
£36.52 ex VAT
£43.82 inc VAT
The Poly Studio P5 webcam ensures you look great on video calls at home, in the office, or wherever you're working. Quality camera optics are fine-tuned so you come across clearly with a powerful, professional-quality image.
  • Quality camera optics
    Put your best foot forward on every call with optics specially designed for video conferencing. Gain confidence that you are clearly seen with brilliant colors designed to show you at your best.
  • Low-light compensation
    Don't let imperfect lighting deteriorate your image during a call. Automatic low-light compensation lets you look your best even in dim environments.
  • Precise camera view
    With people working from more places, background movement, clutter, and household members can detract from your calls. A narrow field of view keeps the focus on the conversation at hand rather than your surroundings.
  • Pro-grade resolution
    A grainy video feed can be distracting for colleagues. With 1080p resolution and a 4x digital zoom camera, you can be sure that your video is crystal clear.
  • Directional microphone
    You're heard clearly with a built-in directional microphone that focuses on your voice, not the noise around you.
Poly Studio P5 - webcam
Webcam
Audio
Yes: built-in unidirectional microphone
Camera Mount Type
Tripod mount
3.7 cm x 3.4 cm x 6.2 cm
68 g
Wired
Camera
Video Modes
720p, 1080p
Focus Adjustment
Automatic
USB 2.0
Software Certification
Certified for Microsoft Teams, Zoom Certified
USB cable - integrated - 1.3 m
ePTZ, privacy shutter, Low Light Compensation (LLC), adjustable monitor clamp, LED indicator, 80° diagonal field of view, Webcam Support (UVC), 50 Hz to 16 kHz microphone frequency response
Environmental Parameters (operating)
0 °C - 40 °C; 5 - 95% RH relative humidity
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
3.7 cm
3.4 cm
6.2 cm
68 g
Camera
Video Modes
720p, 1080p
Digital Zoom
4
Video Capture
1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
Ports
USB 2.0 - 4 pin USB Type A
Monitor mount
Plug and Play
Windows 10, Windows 8.1, Apple MacOS X 10.7 or later
Shipping Width
10.2 cm
Shipping Depth
15.3 cm
Shipping Height
5.5 cm
Shipping Weight
185 g
Relative Humidity (operating)
5 - 95% RH
Type: Coference Unit
Brand: Poly
