Poly P10H/A ADAPTER
Poly P10H/A ADAPTER
Quicklinx: 6NMCWS00 Mfr#: 33117-02
Recommended Use: Accessory
Connectivity: Wired
Earcover : [N/A]
£69.45 ex VAT
£83.34 inc VAT
PBX and ACD operators can enjoy the comfort and convenience of Plantronics technology with the P10 plug prong adapter with built-in high-gain amplifier. The P10 adapter works with your choice of Plantronics headsets so you can choose the style that best meets your application needs. Just plug the P10 adapter into your operator console, PBX, or ACD, then plug in your headset. The P10 adapter delivers Plantronics famous sound quality and ease of use. Its volume and automatic gain controls let you adjust incoming calls to a listening level that's comfortable for you.
The P10H adapter comes with built-in high-gain amplifier.
Poly - Plantronics P10 Series P10H - adapter for headset
Adapter
Intended For
Headset
English
Adapter
Intended For
Headset
English
2 years
Connectivity: Wired
Earcover : [N/A]
Brand: Poly
