Poly Blackwire 8225 USB-A Headset
Quicklinx: HM3QWS00 Mfr#: 772K2AA
Is background noise affecting your productivity? Reduce noise and increase focus with the Poly Blackwire 8225 headset with a noise-canceling microphone enhanced with Acoustic Fence technology and advanced hybrid active noise canceling (ANC).
  • Advanced hybrid ANC
    Optimize audio comfort and quality with advanced hybrid active noise canceling (ANC) by choosing between three settings.
  • Acoustic Fence technology
    Reduce disruptions from close talkers and environmental noise with the flexible, noise-canceling microphone enhanced with Acoustic Fence technology.
  • Connectivity options
    Allows greater flexibility of use by offering choices: USB-A or USB Type-C ?.
  • Lightweight design
    Padded headband and soft leatherette ear cushions provide all-day comfort.
  • Inline control
    Easy-to-use inline call control with call answer / end, mute, volume up / down buttons and a three-setting ANC switch.
  • Communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Poly Blackwire 8225 - headset - USB-A
Headset - wired - USB-A
Recommended Use
Computer, phone
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 84 dB +/- 3dB
Signal-To-Noise Ratio
118 dB
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Answer/end, mute, volume, ANC mode
Software Certification
Zoom Certified
Compatible Software
Zoom
15.5 cm
3.2 cm
17.8 cm
144 g
Earpad Material
Artificial leather
Recommended Use
Computer, phone
2 LED indicators, 280° rotatable microphone, boom mic length 135mm
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Hybrid Active Noise Cancelling
Frequency Response
20 - 20000 Hz
118 dB
Sensitivity
84 dB +/- 3dB
Max Sound Pressure
118 dB
Diaphragm
32 mm
Dynamic EQ optimised, Acoustic Fence technology, SoundGuard DIGITAL Technology
Microphone
Boom
Omni-directional
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Echo Noise Cancelling
Remote Control
Controls
Cable
Cable Length
2.19 m
Supported Host Device OS
Windows 10, macOS
Zoom Certified
Compatible Software
Zoom
Shipping Width
18.3 cm
Shipping Depth
20.9 cm
Shipping Height
5.5 cm
Shipping Weight
332 g
HM3Q Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £12.95
HM3Q Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £24.69
HM3Q Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.68
HM3Q Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.69
HM3Q Poly HIS Adapter Cable In Stock £24.69
HM3Q Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £9.00
HM3Q Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
HM3Q Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
