Poly BLACKWIRE 5220 C5220 USB-A WW
Quicklinx: G29LWS00 Mfr#: 207576-201
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
£78.40 ex VAT
£94.08 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls. The Blackwire 5200 Series - the power to connect and work easily is here.
  • Comfort and durability
    Ideal for all-day use, long conference calls and listening to multimedia, the ultra-soft leatherette ear cushions wrapped around pillow-soft memory foam provide all-day comfort.
  • Intuitive/user friendly features
    One-touch call answer/end, volume+/-and mute with user friendly audio prompts and inline indicator lights alert the user to connection, mute and volume status.
  • Plantronics signature audio
    PC wideband audio with noise-canceling microphones for high-quality PC telephony plus Digital Signal Processing (DSP) provides natural voice sound whilst Plantronics patented technology provides advance audio protection and Dynamic EQ automatically adjusts audio settings between voice calls and music.
Poly Blackwire C5220 USB-A - headset
Headset - wired - USB, 3.5 mm jack
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Series
5200 Series
20.9 cm
5.5 cm
18.6 cm
164.2 g
Headband Material
Cushioned metal
Earpad Material
Leatherette
Recommended Use
Voice alerts
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
SoundGuard Technology
Microphone
Boom
Headset microphone
Frequency Response
100 - 8000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
Carrying case
Cable Details
Headset cable
Connectivity: Wired
Earcover : Binaural
Brand: Poly
