Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C
Quicklinx: J88HWS00 Mfr#: 8X227A6
Hurry, only 1 left in stock!
£41.83 ex VAT
£50.19 inc VAT
The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear monaural
Wired
Audio Specifications
Sensitivity 116 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Mute, volume, answer/end, hold, redial
Software Certification
Certified for Skype for Business, Avaya Certified, Cisco Jabber Certified, UC certified
Series
Compatibility
Mac, Windows
15.5 cm
3.2 cm
17.8 cm
64 g
Earpad Material
Artificial leather
Recommended Use
Boom mic length 130 mm, 270° rotatable microphone
Audio Output
On-ear monaural
Wired
118 dB
Sensitivity
116 dB
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised, echo reduction
Microphone
Boom
Omni-directional
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
USB-C cable, USB-C to USB-A adapter, travel case
Cable Details
USB-C cable
Supported Host Device OS
Windows 10, macOS
Shipping Width
18.5 cm
Shipping Depth
5.6 cm
Shipping Height
20.7 cm
Shipping Weight
221 g
J88H Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.58
J88H Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.71
J88H Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
J88H Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
Brand: Poly
