Poly AUDIO 655 USB PC HEADSET EMEA
Quicklinx: 6NSSWS00 Mfr#: 80935-15
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
More than 50 in stock
£26.49 ex VAT
£31.78 inc VAT
The Plantronics .Audio 655 USB delivers exceptionally high audio using the 40mm speakers - which deliver studio-quality audio with maximum bass response perfect for music, multimedia, gaming and PC chat.
All the controls are intuitively placed for quick and easy control: volume up and down are positioned on the ear pod and with the microphone mute activated when the boom is stowed you will always be in control.
For Internet calling (VOIP) a QuickAdjust microphone provides precise placement and noise-canceling features ensure that Internet callers can hear you clearly. The design ensures excellent comfort for hours of use.
Poly - Plantronics .Audio 655 - headset
Headset - wired
Recommended Use
Computer
EMEA
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Microphone
Built-in - boom
Controls
Volume, microphone on/mute
Headset - wired
Recommended Use
Computer
EMEA
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Diaphragm
40 mm
In-Cord Volume Control
Microphone
Boom
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Plug and Play
Connectivity: Wired
Earcover : Binaural
Brand: Poly
Price Range Ex VAT: 0 - 50
