Your basket is empty
PNY Quadro NVS310 512MB PCI-Express x16 DVI Low Profile
Quicklinx: 89LKWS00 Mfr#: VCNVS310DP-PB
Boost your enterprise's productivity with the NVIDIA NVS 310 by PNY dual-display professional graphics solution. This graphics board provides a reliable hardware and software platform to enable fast, cost-effective integration, deployment, and support across large enterprises. The NVS 310 board features DisplayPort 1.2, NVIDIA Mosaic technology, and NVIDIA NVIEW desktop management software, and can drive up to two 30-bit displays at resolutions up to 2560 x 1600 at 60 Hz. Plus, NVS 310 is designed with the ideal balance of performance and power to meet the needs of today's most demanding business user.
NVIDIA NVS 310 by PNY - graphics card - Quadro NVS 310 - 512 MB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro NVS 310
512 MB DDR3
CUDA Cores
48
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
2 x DisplayPort
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.1
14.5 cm x 6.9 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
CUDA Cores
48
Max Resolution
2
2 x DisplayPort
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia CUDA technology, NVIDIA Mosaic, Nvidia Power Management technology, Shader Model 5.0, HDCP
Size
512 MB
DDR3 SDRAM
Bus Width
64-bit
Bandwidth
14 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Oracle Solaris
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
CD-ROM
19.5 Watt
Low-profile bracket
Software Included
Drivers & Utilities, Nvidia nView Desktop Management Software
14.5 cm
6.9 cm
ENERGY STAR Certified
Limited warranty - 3 years
89LK C2G HDMI to DisplayPort Adapter Converter In Stock £33.32
89LK C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.49
89LK C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
89LK C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £15.00
89LK C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £11.49
