PNY Quadro NVS 510 2GB DDR3 128bit PCIEx16 DVI Low Profile
Quicklinx: 8H4VWS00 Mfr#: VCNVS510DVI-PB
The NVIDIA NVS 510 offers the latest in graphics and display technologies along with industry-leading, multi-display management capabilities in an energy efficient, low-profile form factor. This makes it the ideal graphics solution for professionals who need to efficiently visualize and digest a great deal of information in the financial trading, command and control, and digital-signage markets.
The NVIDIA NVS 510 features four compact mini DisplayPort connectors with a custom built-in retention mechanism, delivering ultra-high resolutions up to 3840 x 2160 at 60 Hz. Plus, it supports advanced DisplayPort features like Multi Stream technology and stream cloning, which enables efficient cable management, as well as cost-effective multi-display installations.
  • Quad display support
    NVS 510 display engine drives up to four displays simultaneously and fully supports the next generation DisplayPort standard capable of resolutions such as 3840 x 2160 at 60 Hz. NVS510, when used with the nView desktop software utility, makes it easy to deploy multiple displays across a desktop or build an expansive digital signage wall.
  • DisplayPort features
    NVS 510's integrated DisplayPort Engine produces phenomenal photorealistic image quality while driving ultra-high-resolution panels. NVS 510 also supports advanced DisplayPort features like multi-stream technology (MST) and stream cloning, which enable efficient cable management. MST allows an end-user to drive up to for independent displays simultaneously from any one display port output, while stream cloning enables NVS 510 to clone up-to four instances of each display output to drive a maximum of 16 displays.
  • Versatile connectivity options using mini DisplayPort connector
    End users can securely connect to the most exhaustive options of display monitors and HDMI capable devices either by using the included mDP to DisplayPort cable to take advantage of widely deployed DiplayPort cables and dongles, or directly connect using mini DisplayPort based cables and dongles.
  • Multi-display experience with NVIDIA Mosaic technology
    Mosaic technology enables seamless taskbar spanning as well as transparent scaling of the desktop and applications across up to 8 displays from a single workstation or PC while delivering full performance and image quality.
  • NVIDIA High-Definition Video technology
    It combines high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing, inverse telecine and high quality dual HD video playback - with low CPU utilization and power consumption.
  • H.264 encoder
    Dedicated H.264 encode engine that's independent of 3D/compute pipeline and delivers faster than real-time performance for transcoding, video editing, and other encoding applications.
  • NVIDIA FXAA and TXAA
    Reduces visible aliasing and delivers higher image quality without the performance hit by harnessing the power of the GPU's CUDA cores and film-style AA techniques.
  • Intelligent power management
    NVS 510's ENERGY STAR compliant design reduces overall system energy costs by intelligently adapting the total power utilization of the graphics subsystem based on the applications being run by the end user. This power-optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability.
  • Large dedicated graphics memory with ultra-fast memory bandwidth
    NVS 510's 2 GB of dedicated memory delivers high throughput needed to drive hardware accelerated dual HD Blu-ray video streams or interact with large textured models on up to 4 ultra-high resolution displays.
  • Power-efficient performance
    The NVS 510 is the ideal graphics solution to natively drive four displays, providing the optimal balance of performance, form factor and power efficiency when compared to dual Graphics Cards configurations. NVS 510 utilizes the latest NVIDIA Kepler GPU technology to deliver over 3x greater performance and doubles the memory bandwidth for faster throughput over the previous generation NVS solutions without increasing overall power consumption.
  • NVIDIA CUDA
    Parallel-computing architecture that enables dramatic increases in computing performance by harnessing the power of the GPU. NVS 510 contains 192 NVIDIA CUDA parallel-computing cores compatible with all GPU-accelerated web, photo, video applications, as well as next-generation Internet technologies.
  • Ultra-quiet high reliability cooling solution
    It built with a highly reliable, ultra-quiet fansink that efficiently cools the graphics without taxing the system fans resulting in a quieter desktop environment, as well as enabling multi-NVS510 configurations in workstations and desktop systems.
NVIDIA NVS 510 - graphics card - NVS 510 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 510
2 GB DDR3
CUDA Cores
192
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 1920 x 1200 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz
Max Monitors Supported
4
4 x Mini DisplayPort , 4 x DisplayPort - with adapter , 4 x DVI-D (Single-Link) - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
16 cm x 6.89 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 510
CUDA Cores
192
Max Resolution
4
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, TXAA, Dual-stream Hardware Acceleration, GPU Tessellation, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture, HDCP
Size
2 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
28.5 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Oracle Solaris, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
33.4 Watt
Low-profile bracket
4 x Mini DisplayPort-DisplayPort cable , 4 x Mini DisplayPort-DVI cable
Software Included
Drivers & Utilities, Nvidia nView Desktop Management Software
UL, WHQL
16 cm
6.89 cm
ENERGY STAR Certified
Limited warranty - 3 years
8H4V C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - White In Stock £12.08
8H4V C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - Black In Stock £12.08
8H4V C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black In Stock £23.98
8H4V C2G 2m Mini DisplayPort Cable M/M - White In Stock £12.42
8H4V C2G 2m Mini DisplayPort Extension Cable M/F - White In Stock £14.02
8H4V C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter Cable - Black In Stock £10.17
8H4V C2G 20cm Mini DisplayPort Male to Single Link DVI-D Female Adapter Cable - White In Stock £10.78
8H4V C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black In Stock £15.22
8H4V C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £16.02
8H4V C2G 20cm Mini DisplayPort Male to VGA Female Adapter White In Stock £18.80
