Your basket is empty
PNY Quadro FX 6000 6GB DDR5 PCI-Express 384bit DVI
Quicklinx: 7868WS00 Mfr#: VCQ6000-PB
  • DisplayPort
Built on the innovative Fermi architecture and providing 448 NVIDIA CUDA parallel processing cores, the Quadro 6000 delivers faster performance across a broad range of design, animation and video applications.
Modern applications harness the NVIDIA CUDA parallel processing architecture of Quadro GPUs to deliver performance gains faster when running computationally intensive applications such as ray tracing, video processing and computational fluid dynamics. For high-precision, data-sensitive applications, Quadro is the only professional graphics solution with ECC memory and fast double precision capabilities to ensure the accuracy and fidelity of your results. From medical imaging to structural analysis applications, data integrity and precision is assured, without sacrificing performance.
NVIDIA Quadro 6000 by PNY - graphics card - Quadro 6000 - 6 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro 6000
6 GB GDDR5
Memory Interface
384-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
2
DVI-I (dual link) , 2 x DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.0
Package Type
Retail
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro 6000
Max Resolution
2560 x 1600 at 24 Hz
2
API Supported
Nvidia GeForce 3D Stereo technology, High dynamic-range (HDR) rendering, Nvidia CUDA technology, Nvidia GigaThread technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, Nvidia SLI Mosaic Technology, HDCP
Size
6 GB
GDDR5 SDRAM
Bus Width
384-bit
Video Output
Colours Max Resolution (external)
30-bit colour
SunSoft Solaris, Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Required Power Supply
600 W
Additional Requirements
CD-ROM
System Requirements Details
Pentium 4 RAM 1 GB - HDD 100 MB
Stereo connector bracket
1 x DVI-VGA adapter , 1 x DisplayPort-DVI adapter
Software Included
Display drivers
Package Type
Retail
7868 C2G HDMI to DisplayPort Adapter Converter In Stock £33.81
7868 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.79
7868 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
7868 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £15.23
7868 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £11.68
