Designed to be the performance leader in double precision applications and the broader supercomputing market, the K20X GPU Accelerators deliver 10x, the performance of a single CPU. Tesla K20X features a single GK110 Kepler GPU that includes, the dynamic parallelism and Hyper-Q features. With more than one teraflop peak double precision performance, these GPU accelerators are ideal for the most aggressive high-performance computing workloads including climate and weather modeling, CFD, CAE, computational physics, biochemistry simulations, and computational finance
With teraflops of single and double precision performance, NVIDIA Kepler GPU computing accelerators are the world's fastest and most efficient high performance computing (HPC) companion processors. Based on the Kepler compute architecture, which is 3 times higher performance per watt than the previous "Fermi" compute architecture, the Tesla Kepler GPU computing accelerators make hybrid computing dramatically easier, and applicable to a broader set of computing applications. NVIDIA Tesla GPUs deliver the best performance and power efficiency for seismic processing, biochemistry simulations, weather and climate modeling, image, video and signal processing, computational finance, computational physics, CAE, CFD, and data analytics.
ECC memory error protection
It meets a critical requirement for computing accuracy and reliability in datacenters and supercomputing centers. External DRAM is ECC protected in Tesla K10 and both external and internal memories are ECC protected in Tesla K20X. -
System monitoring features
It integrates the GPU subsystem with the host system's monitoring and management capabilities such as IPMI or OEM-proprietary tools. IT staff can thus manage the GPU processors in the computing system using widely used cluster/grid management solutions. -
L1 and L2 caches
Accelerates algorithms such as physics solvers, ray-tracing and sparse matrix multiplication where data addresses are not known beforehand. -
Asynchronous transfer with dual DMA engines
Turbocharges system performance by transferring data over the PCIe bus while the computing cores are crunching other data.
- NVIDIA Tesla K20X - GPU computing processor - Tesla K20X - 6 GB
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA Tesla K20X
- Memory
- 6 GB GDDR5
- CUDA Cores
- 2688
- Memory Interface
- 320-bit
- 26.5 cm x 11 cm
- Bus Type
- Graphics Engine
- NVIDIA Tesla K20X
- CUDA Cores
- 2688
- Nvidia CUDA technology, Error Correcting Codes (ECC) Memory, dual slot heatsink, SMX technology, Kepler GPU Architecture, Dynamic Parallelism, Hyper-Q
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 320-bit
- Bandwidth
- 250 GBps
- Additional Requirements
- Two 6-pin power connectors
- 225 Watt
- 26.5 cm
- 11 cm
