PNY NVIDIA Telsa K80 24GB GDDR5 PCI-E X16 Graphics Card
Quicklinx: B9RXWS00 Mfr#: TCSK80M-PB
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA Tesla K80
Interface: PCI Express 3.0 x16
Memory Size: 24GB
Digital Output: Digital Visual Interface (DVI)
£4,051.34 ex VAT
£4,861.60 inc VAT
The Tesla K80 dual-GPU accelerator, is the world's highest performance accelerator designed for a wide range of machine learning, data analytics, scientific, and high performance computing applications.
The Tesla K80 dual-GPU is the flagship offering of the Tesla accelerated computing platform, the leading platform for accelerating data analytics and scientific computing. It combines the world's fastest GPU accelerators, the widely used CUDA parallel computing model, and a comprehensive ecosystem of software developers, software vendors, and datacenter system OEMs. The Tesla K80 dual-GPU accelerator delivers nearly two times higher performance and double the memory bandwidth of its predecessor, the Tesla K40 GPU accelerator. With ten times higher performance than today's fastest CPU, it outperforms CPUs and competing accelerators on hundreds of complex analytics and large, computationally intensive scientific computing applications. Users can unlock the untapped performance of a broad range of applications with the accelerator's enhanced version of NVIDIA GPU Boost technology, which dynamically converts power headroom into the optimal performance boost for each individual application.
  • Industry-leading performance for science, data analytics, machine learning
    The Tesla K80 dual-GPU accelerator was designed with the most difficult computational challenges in mind, ranging from astrophysics, genomics and quantum chemistry to data analytics. It is also optimized for advanced deep learning tasks, one of the fastest growing segments of the machine learning field.
NVIDIA Tesla K80 - GPU computing processor - 2 GPUs - Tesla K80 - 24 GB
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GPUs - NVIDIA Tesla K80
24 GB GDDR5
Core Clock
560 MHz
Boost Clock
875 MHz
CUDA Cores
4992
Effective Memory Clock
2.5 GHz
Memory Interface
384-bit
API Supported
OpenACC
Fanless
11.115 cm x 26.7 cm
Environmental Standards
ENERGY STAR Qualified
GPU computing processor - fanless
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
560 MHz
Boost Clock
875 MHz
CUDA Cores
4992
API Supported
OpenACC
Dual slot heatsink, SMX technology, NVIDIA GPU Boost, Kepler GPU Architecture, Dynamic Parallelism, Hyper-Q
Size
24 GB
GDDR5 SDRAM
Effective Clock Speed
2.5 GHz
Bus Width
384-bit
Bandwidth
480 GBps
Microsoft Windows (64 bit), Linux (64-bit)
300 Watt
11.115 cm
26.7 cm
ENERGY STAR Certified
Memory Size: 24GB
Brand: PNY
Price Range Ex VAT: 1500+
