PNY NVIDIA QUADRO NVS 810 4GB DDR3 128-bit PCI-E X16 8*Mini DisplayPort
Quicklinx: BWFMWS00 Mfr#: VCNVS810DP-PB
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA NVS 810
Interface: PCI Express 3.0 x16
Memory Size: 4GB, 4GB
£617.49 ex VAT
£740.98 inc VAT
Build cost-effective, reliable signage solutions with the 8 display output, single slot form factor NVIDIA® NVS™ 810
The NVIDIA NVS 810 graphics board delivers exceptional display connectivity, cost-effective scalability, and image management capabilities that make it easy to drive any kind of multi-display digital signage setup. It’s the first of its kind to offer eight display outputs, combined with the world’s most advanced GPU architecture—all in a single-slot form factor. NVS 810 is also ideal for creating dense signage solutions, delivering the uncompromised performance and reliability required to deploy demanding content in mission-critical signage installations.
Eight mini-DisplayPort 1.2 connectors on the NVIDIA NVS 810 are capable of driving UHD 4K displays at 60 Hz. Plus, it provides advanced features like multi-streaming and stream cloning that enable extremely efficient cable management and display flexibility in complex installations. Key NVIDIA features like bezel correction, synchronization across 8 displays, Warp & Blend, and Mosaic make digital signage easy.
PNY provides unsurpassed service and commitment to its professional graphics customers including a 3 year warranty, pre- and post-sales support, dedicated Quadro Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, and a driver and documentation software installation disc to ensure a quick and successful install.
NVIDIA NVS 810 - graphics card - 2 GPUs - NVS 810 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GPUs - NVIDIA NVS 810
4 GB DDR3
CUDA Cores
1024
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
8
8 x Mini DisplayPort , 8 x DisplayPort - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
19.8 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
CUDA Cores
1024
Max Resolution
4096 x 2160 at 60 Hz
8
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, TXAA, FXAA, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, NVIDIA GPU Boost, Multi-stream hardware H.264 encoder, Nvidia Quadro Warp/Blend, Bezel Compensation, Maxwell architecture, HDCP
Size
4 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
28.8 GBps
Linux, Oracle Solaris, Windows 8, Windows 8.1, Windows 10
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
CD-ROM
68 Watt
8 x Mini DisplayPort-DisplayPort adapter
Software Included
Drivers & Utilities, Nvidia nView Desktop Management Software
WHQL
19.8 cm
11.2 cm
468 g
ENERGY STAR Certified
Limited warranty - 3 years
BWFM C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - White In Stock £11.69
BWFM C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - Black In Stock £6.34
BWFM C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black In Stock £15.40
BWFM C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter Cable - Black In Stock £7.82
BWFM C2G 20cm Mini DisplayPort Male to Single Link DVI-D Female Adapter Cable - White In Stock £10.45
BWFM C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black In Stock £14.74
BWFM C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £15.51
Memory Size: 4GB
Memory Size: 4GB
Brand: PNY
Price Range Ex VAT: 500 - 750
