NVIDIA Quadro 410 by PNY is tested and certified to reliably accelerate all major design and CAD applications to keep you productive regardless of how complex your workflow gets. Take advantage of improved model interactivity or tackle more demanding models with up to 90% CAD performance improvement over the Quadro FX 380 LP. Professional features like FXAA and TSAA full scene anti-aliasing provide crisper images without impacting model interactivity.
Designed for efficiency, Quadro 410 consumes only 38 W and has a low-profile footprint flexible enough to fit into any workstation. NVIDIA Mosaic and NVIEW technologies allow you to span and efficiently manage your entire Windows desktop across multiple displays.
The NVIDIA Quadro 410 supports OpenGL 4.2, DirectX 11, Shader Model 5.0, CUDA, and drives displays ranging from CRTs and digital flat panels to projectors and HDTVs.
GPU Tessellation with Shader Model 5.0
Quadro Tessellation Engines automatically generate finely detailed geometry, for cinematic quality environments and scenes, without sacrificing performance. -
NVIDIA High-Precision High Dynamic Range (HDR) technology
It sets standards for image clarity and quality through floating-point capabilities in shading, filtering, texturing, and blending and enables unprecedented rendered image quality for visual-effects processing. -
DisplayPort 1.2 support
Compact and secure DisplayPort 1.2 connectors support Multi-Stream technology, stream cloning and ultra-high-resolution panels - enabling maximum range, resolution, refresh rate, and color depth designed to support the latest display technologies. -
30-bit color fidelity
30-bit color fidelity enables billions of color variations for rich, vivid image quality with the broadest dynamic range. -
3D Vision and 3D Vision Pro
Advanced active shutter glasses deliver crystal-clear stereoscopic 3D visualization for the most immersive experience. Infrared (3D Vision) or RF (3D Vision Pro) technology enables a range of immersive environments ranging from your desktop workstation to collaborative work spaces. -
OpenGL quad buffered stereo support
OpenGL quad buffered stereo offers professional applications the capability of smooth and immersive 3D Stereo experience.
- NVIDIA Quadro 410 by PNY - graphics card - Quadro 410 - 512 MB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA Quadro 410
- Memory
- 512 MB DDR3
- CUDA Cores
- 192
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 3840 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 3840 x 2160 / VGA: 2048 x 1536
- Max Monitors Supported
- 2
- DVI-I (dual link) , DisplayPort , DVI-D (Single-Link) - with adapter , VGA - with adapter
- API Supported
- DirectX 11, Cg, OpenGL 4.4
- 17.6 cm x 6.9 cm
- Package Type
- Bulk
- 3-year warranty
- Bus Type
- Graphics Engine
- NVIDIA Quadro 410
- CUDA Cores
- 192
- RAMDAC
- 400 MHz
- Max Resolution
- 3840 x 2160
- 2
- API Supported
- Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Nvidia 3D Vision Pro, TXAA, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture, Nvidia High Precision Dynamic Range (HPDR) Technology, OpenGL Quad Buffered Stereo Support, HDCP
- Size
- 512 MB
- Technology
- DDR3 SDRAM
- Bus Width
- 64-bit
- Bandwidth
- 14 GBps
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Oracle Solaris, Windows 8
- Min RAM Size
- 1 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM
- 38 Watt
- Included Accessories
- ATX bracket
- Cables Included
- 1 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
- Software Included
- Display drivers
- 17.6 cm
- 6.9 cm
- Package Type
- Bulk
- Limited warranty - 3 years
