PNY NVIDIA Quadro NVS 315 1024MB PCI-E X16 Dual DVI/VGA Professional Graphics Card
Quicklinx: 9FGCWS00 Mfr#: VCNVS315DVI-PB
The NVS 315 delivers incredible flexibility, scalability, and compatibility that lets you get the most from your existing display infrastructure. This version of the NVS 315 can drive all of your existing DVI or VGA displays. NVIDIA nView and Mosaic work with the NVS 315 to provide a whole new way to maximize your productivity. Easily manage many windows across multiple high-resolution displays and virtual desktops with a panoramic overview of your entire workspace. Best of all, the NVS 315 is designed with simplified IT management in mind, including advanced tools that make integrating and maintaining a large-scale PC deployment fast and easy.
PNY provides unsurpassed service and commitment to its professional graphics customers offering: pre- and post-sales support, dedicated NVS Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, driver disc and documentation to ensure a quick and successful install.
NVIDIA NVS 315 - graphics card - Quadro NVS 315 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
1 GB DDR3
CUDA Cores
48
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
2048 x 1536
Max Resolution Details
DVI: 1920 x 1080 / VGA: 2048 x 1536
Max Monitors Supported
2
2 x DVI-I (Single-Link) - with adapter , 2 x VGA - with adapter , DVI-I (DMS-59)
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
14.5 cm x 6.94 cm
Package Type
Retail
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
CUDA Cores
48
RAMDAC
400 MHz
Max Resolution
2048 x 1536 at 85 Hz
2
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Dual-stream Hardware Acceleration, GPU Tessellation, Nvidia Unified GPU Architecture, ultra-quiet active fansink, HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
64-bit
Bandwidth
14 GBps
Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3, Oracle Solaris, Windows 8
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
19.5 Watt
Low-profile bracket
1 x DMS-59 to 2 x DVI cable , 2 x DVI-VGA adapter
Software Included
Display drivers, Nvidia nView Advanced Desktop Software
14.5 cm
6.94 cm
Package Type
Retail
ENERGY STAR Certified
Limited warranty - 3 years
9FGC C2G DVI-A Male to HD15 VGA Female Video Adapter In Stock £9.11
9FGC C2G DVI-A Female to HD15 VGA Male Video Adapter In Stock £8.87
9FGC C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £12.11
9FGC C2G 2m DVI-I M/M Dual Link Digital/Analogue Video Cable In Stock £11.97
